Thanks for the tips Tony! The lever arm is moving up/down freely, w/o resistance. I'm going to try to find a way to inspect the plunger while operating the lever, perhaps using mirror or camera.
1983 911 SC Coupe w Sunroof, Metallic Silver --- AKA 83 Silberpfeil
Old 03-27-2023, 09:13 AM
PCA Member since 1988
Of course, Tony is correct, but I like quick and easy tests that allow me to kill off legs in the troubleshooting path and (hopefully) save time. Were you able to get the injectors to squeak (showing they are delivering fuel) by lifting the arm (as Ossiblue and Tony suggested) during your tests so far?
If so, then let me suggest this: with the car off, push up on the arm that holds the sensor plate. It will have very little resistance. Let it back down and push it up a few more times. It should feel about the same, and calibrate your factory-installed precision digital sensor (finger) for the amount of force it takes. Then turn on the fuel pump, and push up again and let it back down. It should take more force and you should feel it push the arm back down against your finger. That is the control pressure pushing down on the top of the plunger, and showing that the plunger moves. If in doubt, you can do this a few more times to be sure. Just be aware that when you do this you will squirt fuel through the injectors in to the intake ports (and you will hear them operating), so don't sit there holding the arm up. And then crank the engine to clear the excess fuel.
If that doesn't produce the desired results, then I think you need to remove the FD and squirt carb cleaner into it to free up the plunger. I had a stuck plunger on a car that sat for 20+ years, and a few squirts of carb cleaner, plus pressing on the plunger a few times, freed it up. You can also try putting a LITTLE air pressure into the control pressure port, but be VERY careful you do not shoot the plunger out of the FD and onto the floor, because it is a HIGH precision part, and if you scuff it up, it's damaged and you will need a new FD. Hold the FD in the palm of your hand to keep the plunger contained in the FD body. Proceed with caution.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 03-27-2023, 03:41 PM
Thanks for your suggestion PeteKz. SkiVT suggested this test procedure a few posts above; glad that you are reinforcing/corroborating. Great minds think alike.
I will go back into the engine bay and check the lever again and pay attention, and try to replicate what you and SkiVT and Tony prescribed. Yesterday, once I got the lever and sensor plate to move freely up/down, I didn't detect any resistance when pushing up. There could have been a tiny bit, so I will check again.
For sure, I'm all for quick and easy tests. Hopefully it will be all good, and won't have to remove anything to check.
Originally Posted by PeteKz View Post
Of course, Tony is correct, but I like quick and easy tests that allow me to kill off legs in the troubleshooting path and (hopefully) save time. Let me suggest that with the car off, push up on the arm that holds the sensor plate. It will have a slight amount of resistance. Let it back down and push it up a few more times. It should feel about the same, and calibrate your factory-installed precision digital sensor (finger) for the amount of force it takes. Then turn on the fuel pump, and push up again and let it back down. It should take more force and you should feel it push the arm back down against your finger. That is the control pressure pushing down on the top of the plunger, and showing that the plunger moves. If in doubt, you can do this a few more times to be sure. Just be aware that when you do this you will squirt fuel through the injectors in to the intake ports (and you will hear them operating), so don't sit there holding the arm up. And then crank the engine to clear the excess fuel.
Old 03-27-2023, 03:55 PM
NO FUEL DELIVERY --- what to do next?
So, I finally gave this a try. First added ~ 2.5 fresh Super Unleaded fuel, along w ~ 10 oz Chevron Techron. Is that enough fuel to get engine started? The tank was completely drained/empty before.
- removed air filter
- checked the FD / air lever --- it moves up/down freely
- turned key to run position
- lifted the lever inside the airbox
I was waiting for some noise to come in, and signs of fuel delivery; nothing happened. No noise of injectors activating, no fuel running spraying anywhere, even with the FD lever lifted up. I tried this a few times, even lifting the lever up for 5 ~ 6 seconds. Nothing happened.
Shut ignition, removed key. Inspected the fuel filter connections --- no leaks, probably no fuel flowed.
Should next step be inspecting/diagnosing the fuel pump? Does it run? Does it get proper voltage/current? Then go downstream towards accumulator?
I reinstalled the air filter. Then tried to start the car. The starter turns, engine is turning, oil pressure gauge indicates pressure is trying to build up, but doesn't start.
Would appreciate suggestions/recommendations.
Thanks!
Last edited by 83_Silberpfeil; 04-01-2023 at 05:23 PM.. Reason: added subject/header: No fuel delivery
Old 04-01-2023, 05:22 PM
I just quickly re-scanned the thread. I don't think you have verified that your fuel pump runs.
Do this: Jumper the FP relay as described above. Turn on the key to Ignition. You should hear the fuel pump running. If not, that is where you focus next. Report back your findings.
Old 04-01-2023, 06:08 PM
Hi Pete - I'll try anything at this point. Thank! I have a Bentley manual, and it has foto showing: jump "30 to 87a" --- see foto below. It shows a fancy jumper wire w a fuse and switch. Do I really need all that? Where to buy?
I searched and found another thread here, and it simplifies the process into:
- Take out your Fuel pump relay and jump (with a chunk of wire) across terminals 87A and 30.
- Turn the key to the on position.
- You should hear the pump running.
Is that all there is to it? Find a piece of wire and bridge the two terminals 87a and 30?
Old 04-01-2023, 08:21 PM
Jonathan,
If you are willing to gamble burning your wiring harness during your investigations, you could use jumper wires without a fuse. But I would NOT recommend doing it specially for someone like you.
To play safe, using a set of wire jumpers with fused installed is a prudent course of action. If you have not read DKLever48’s post about testing the FP Relay Socket terminals (87A, 87, 86, 85, & 30), please spend a few minutes reading it.
Install a pressure gauge and find out if your FP is operating when terminal #30 is energized.
Tony
Old 04-01-2023, 09:02 PM
Hi Tony - thanks for pointing out the risk. Makes sense to add a fuse. I'm going to Home Depot and O Reilly tomorrow to pick up the parts and build my own fancy jumper wire.
- toggle switch on/off from Home Depot
- fuse holder and 15 or 20 amp fuse from O Reilly auto parts; my Bentley manual lists FP fuse #16 rated at 25 amps; so will go w 15 or 20 to be safe
- bullet style crimp connector from HD
- 14 gauge or thicker wire from HD
I spent more than a few minutes --- over 1 hr reading the entire DKLever48 thread on FP troubleshooting. Great thread, lots of very detailed explanations for the less experienced like myself. Thanks for pointing that out Tony.
Old 04-01-2023, 11:37 PM
Since Tony replied, I'll defer.
Old 04-02-2023, 12:39 AM
Tony & PeteKz --- Reporting back. I put together a proper jump wire w a 20 amp fuse and on/off toggle switch. See foto below.
The result : FP not running; I stuck my head under the car, and hand touching the belly pan where the FP would be just above. Did not hear anything; did not feel any vibration, or any signs of a moving mechanism down there.
Here's what I did, exactly:
FIRST TEST:
- removed red FP relay
- inserted one jump wire (JW) test lead (TL) into slot # 30 (6 o'clock)
- inserted the other JW TL into slot # 87a (11 o'clock)
- toggle switch in JW is "OFF"
-inserted car key, move to "ON" position
- flipped JW toggle switch to "ON
- CDI buzzing goes on
- I crawl under car to listen, put hand on belly pan near the FP position --- nothing moving, no sound down there. FP not turning on.
SECOND TEST:
- one jump wire (JW) test lead (TL) into slot # 30 (6 o'clock)
- other JW TL into slot # 87a (11 o'clock)
- toggle switch in JW is "ON"
- I crawl under car to listen, put hand on belly pan near the FP position --- nothing moving, no sound down there. FP not turning on. Same result.
What's next? Connect battery power directly to FP? What is the procedure? What equipment do I need?
Thanks!
Old 04-02-2023, 03:12 PM
Adding foto of my jump wire set-up for the FP relay jump test
test
Old 04-02-2023, 03:13 PM
Did you check for 12 volts at the hot pin in the relay socket? Turn the key back on and check that you have voltage to the socket. If you do, then try jumping from the battery directly to the fuel pump pin in the relay socket (through your fuse setup). If it works, then you have to trace back to the fuse block to find what is broken or disconnected. Double check that FP fuse is good.
If it still does not run, then you will have to jack up the car and take off the splash cover and run a wire from the battery directly to the fuel pump. Measure the ohms to ground from the FP to make sure that's not causing the problem (should be zero ohms). If the FP runs, then you have to find where the wire to the FP is broken, or a corroded connection. If the FP does not run with 12 volts directly to it, then it is bad.
Old 04-02-2023, 06:41 PM
Troubleshooting FP Relay Socket Terminals.......
Jonathan,
You could easily identify your electrical problem/s by replicating or doing DKLever48’s Tests. Follow the test procedures and post your test RESULTS. A simple way to test your FP is to:
  • Apply 12 volts directly to terminal #30 (relay socket) @ 6 O’clock.
  • Or apply 12 volts directly to the positive (+) terminal of the FP.
If the FP is bad or defective, pull it out and test it on the bench. There is a small chance the ground contact is missing. Keep us posted.
Tony
Old 04-02-2023, 07:39 PM
Pete/Tony --- thanks both for replying w next steps.
Pete --- No, I did not check voltage at all. I'd like to try that next. And, it sounds like you and Tony both are suggesting the same.
So, using my jump wire, insert one pin into #30 (as Tony mentioned), and the other pin to the +positive lead on the battery?
Then, for direct battery to FP test --- battery positive terminal to FP positive terminal?
Old 04-02-2023, 09:59 PM
Yes, we are suggesting the same thing. But we are looking at it as a step by step process to troubleshoot from the relay socket to the FP. As Tony recommended, slow down for a few minutes, think this through, and re-read DKLever48 post. Do One thing at at time.
First, do you have 12v at the socket when you turn on the key? Report you result.
Old 04-03-2023, 02:30 PM
Tony & PeteKz - I believe I've confirmed I have 12V @ FP socket.
I've completed the tests outlined by Tony for Dklever48. I used my multimeter. Here are my results (also in my notes/foto below):
Here is the basic test for the FP and relay circuitry:
1). Pull out the FP relay and do the test (ignition switch @ OFF position) for the individual terminal at the socket: A simple 12-volt self-powered test light will work well for this test or a regular non-powered test light, or a volt meter.
87...........no power
87a.........no power
86...........no power (87a 86 are bridged)
85...........no power (should be grounded at this point)
30...........no power (has ground contact?)
MY RESULTS: no power on all ports on the socket; checks with Tony's expected results.
2). Turn ignition switch @ ON position (not start):
87............no power
87a..........has power
86...........has power
85...........no power, presence of ground contact
30...........no power, presence of ground contact
MY RESULTS: no power @ 87 / 85 / 30 ; 12.2 V @ 87a and 86; checks with Tony's expected results.
3). Next, insert the FP relay into the socket and turn the ignition SW @ ON position (not start):
87...........has power
85...........should have ground contact
30...........no power but exhibit ground contact.
QUESTION: Is this next step? How do I do this test if the relay is inserted into the socket? Or, do we already know enough to go to the FP itself?
ADDITIONAL TEST: I also tested the fuse that supports the FP, Fuse #16 per Bentley manual. Key @ ON position. I got 12.2 V ; 14.4 ohms resistance (is this too high?) IGNORE THIS TEST RESULT - I didn't measure correctly
Last edited by 83_Silberpfeil; 04-03-2023 at 05:27 PM.. Reason: added comment RE: resistance measurement
Old 04-03-2023, 03:54 PM
I don't recall: Did you have a spare relay that you substituted to make sure it wasn't the relay? Maybe that was someone else. Also check to see if the relay clicks when you turn on the key (with the arm/metering plate on the engine propped open).
Anyway, I think it's time to go under the car and see if you have +12v at the FP positive terminal, when you put the jumper into the relay socket. And check that the ground from the fuel pump is good.
If you have 12v volts at the pump and the ground is good, and it doesn't run, then the fuel pump is bad.
Old 04-03-2023, 04:29 PM
No that was another discussion thread or another member at this Forum.
Agree, need to test for 12V at the FP itself, and confirm it is grounded properly.
Old 04-03-2023, 05:35 PM
Test #3 has several errors......
Jonathan,
The section you quoted (Test #3) was corrected. See post #28 of the above thread. And continue to read after post #28 for more information. Ignore “Test #3 Results” until to read post #28 up to several posts later.
SUMMARY:
I made several “typo” in the test #3 posting and nobody noticed the mistakes until I noticed them. In short, continue reading further down the thread until you read the correction I posted.
Tony
Old 04-04-2023, 08:05 AM
Jonathan: I'll anticipate that you will go under the car and check for 12 volts and ground at the fuel pump terminals. If those test correctly, then your fuel pump is bad, but here is one other thing to try while you are down there: Whack the fuel pump with a small mallet or block of wood. It may start running again. If it does, it may continue to run long enough (weeks? Months?) to get the rest of your work done.
Old 04-04-2023, 11:43 AM
