no top motor numbers
motor has no numbers all have been grinded off.can someone post pick of any date codes or serial numbers picture locations, that would be underneath .all i know its a 2.7 motor thank you
No it’s very tough without the top numbers. There is a part number on the two case halves very easily seen from underneath that can help narrow it down some. I also think there may be a casting year underneath somewhere. I don’t think you will be able to determine whether it’s US spec, Japan or ROW without taking it all apart and a total expert looking at it. To clarify both the serial number and the case type number are missing?
Hi John..if it would be 2,7 it would have to have green engine cover not red..more likely 911sc motor
What year is the 911?The sticker(yellow) on top of the alternator housing is saying what? Ivan |
Identifying an unknown motor........
John,
Without the engine number on the crankcase, I would investigate the external engine parts for forensic identification. If you could provide the part numbers for these: a). Any trace of the engine type number located at right topside of the crankcase? b). Alternator fan housing number? c). Intake runners (2R or 4R)? d). Information on the sticker (alternator strap)? e). Rotational direction of the of the ignition distributor. f). CIS components: WUR FD AAR Throttle body Air flow meter CDI Ignition distributor Etc. The air filter cover is from pre-SC engines. Identify if the crankcase is made of Mg or Al. Putting all these informations together would help you come to a better conclusion. Keep us posted. Thanks. Tony |
yellow is says 1972
car is a 1973,5 that sticker says 1972
its a 2.7 engine I've been told
The casting numbers on the case halves by the oil return tubes?
The double bolt fan housing retainer, early production Bruce |
/Users/johnjohn/Desktop/IMG_7533.jpg/Users/johnjohn/Desktop/IMG_7532.jpg/Users/johnjohn/Desktop/IMG_7535.jpg
john , your engine numbers should be here-green and red arrows, or is yours like this one?
mine looks like that
gearhead
73.5 will be a 2.4 on a 7R case. It the spirits were made larger on a rebuild one could install 2.7 p&c
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Hi John looks like you got your self pretty nice car with a nice engine..you did not mentioned if it is running?Could be 1973 911S...do you have papers for the car ?there is no info there?
here is a list to go by... 901.101.101.01 901.101.102.01 AL 1 5071 901.101.101.10 901.101.102.10 sandcast MG for 906 engines 901.101.101.02 901.101.102.01 AL 5224 9272 901.101.101.0R 901.101.102.0R AL 9730 12050 901.101.101.1R 901.101.102.1R MG 12134 15415 901.101.101.2R 901.101.102.1R MG 17421 1970 901.101.101.3R 901.101.102.2R MG 1970 901.101.101.3R 901.101.102.3R MG 1971 901.101.101.4R 901.101.102.3R MG 1972 901.101.101.5R 901.101.102.4R MG 1973 901.101.101.5R 901.101.102.7R MG 1973 901.101.101.7R 901.101.102.7R MG 1973 1977 901.101.101.7R 901.101.102.7R AL 1973 RSR 911.101.103.0R 911.101.104.0R AL 1973 930.101.103.4R 930.101.104.4R AL 1978 1980 930.101.103.6R 930.101.104.5R AL 1983 |
Near the 901.101.101.7r case number "should" be a casting date mark. see if you can get a pic and post that. Then we might be able to say if it was originally a 2.4 or a 2.7. It might be an unstamped replacement block 2.7.
75 911s 86 951 sold to make room for baby seat 09 335i 6MT NVH |
its a t targa from factory its not matching motor.just trying to figure out what motor
no didn't get it running yet
/Users/johnjohn/Desktop/IMG_1630.JPG
