Tony
Maxhouse97's Avatar
How far to press in rear hub?
See below - is there a clearance between the back of the hub and the bearing face? As far as I can tell, there is no physical stop when pressing it in.
Tony
22 GT4
04 E46 M3
87 Carrera (sold - craving aircooled again)
12 991 Carrera (sold)
Old 11-19-2017, 06:10 AM
Did you support the inner, inside race when you pulled it in? The bearing will be damaged if you didn't. Put the stub axle through and tighten the nut to finish if you don't have the install tool.
206 637 4071
Old 11-19-2017, 10:58 AM
Tony
Maxhouse97's Avatar
No sorry - those pics above are not mine, just to illustrate what clearance is was talking about. I have yet to start pressing it in.
Old 11-19-2017, 11:13 AM
Tony
Maxhouse97's Avatar
I guess I’ll just go until they are flush with the stub axle. Thanks.
Old 11-19-2017, 03:34 PM
seafeye's Avatar
I think once you put in the drive shaft. Attach the bolt and washer. Torque the mother. It will slide home.
What me speed?
Old 11-19-2017, 03:59 PM
