Question Reinstallation of Heads - Loctite?
I am reassembling my engine. Is it necessary to seal the individual heads to the camshaft housing? My rebuild manuals do not mention this, but when I tore the motor down, the previous rebuild had sealed them with Loctite.
Old 02-11-2003, 01:59 PM
Super Moderator
cstreit's Avatar
Yes. This is an oil seal.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-11-2003, 02:07 PM
Irrationally exuberant
ChrisBennet's Avatar
They are sealed from the factory with Loctite 574 (orange stuff). I use Loctite 518. Whatever you do, don't use any sort of RTV or silicone sealants.
-Chris
Old 02-11-2003, 02:16 PM
if you use 574, be sure to use only a very thin, even layer, like what you would get by using a tiny roller, (which is what the factory uses), or it can set up too thick and keep the cam tower from lining up with the heads properly. it's anaerobic, so it starts to set when deprived of oxygen. personally, i like dirko. you have lots of time to work with it.
206 637 4071
Old 02-11-2003, 02:24 PM
Thanks.
'73 911 Targa (Project Car)
'68 Meyers Manx Dune Buggy (Corvair Powered)
'02 BMW 330i (Wife's Car)
Old 02-11-2003, 02:31 PM
