Recently Disbanded
juanbenae's Avatar
weltmeister spring plate adjust range
will be installing a set of weltmeister rear spring plates over the weekend and was wondering what the range of height adjustment is? having set up a number of cars with OE adjustable spring plates over the years I would always set the height adjustment to mid point upon reinstall using Thom's SP angle calculator. expecting 3/8" or so fender height adjust range at the mid point setting going lower or higher upon final set up.
here is the WM page for the plates and it does not note an expanded range. http://www.weltmeister.com/ProductDetails20cd.html?ProductID=372
will the range of adjustment mimic the OE SP of 3/4" or so total fender height range? or can I expect more or less adjustment by setting the WM units half way when setting SP angle upon reassembly?
ive never used the WM plates, have you?
Old 11-22-2017, 07:36 PM
Recently Disbanded
juanbenae's Avatar
anyone? setting the angle of my dangle in minutes here...
Old 11-24-2017, 11:15 AM
