drag racing the short bus
dd74's Avatar
Tire size question for a narrow body 911
Can I run 225-50-15 on 15x7 Fuchs at all four corners? I'm looking at Yokohama A023R tires.
I'm also wondering how much negative camber I might have to dial in.
Anyone run tires this size on their narrow bodies?
Thank you.
The Terror of Tiny Town
Old 02-10-2003, 10:54 PM
Senior Member
Zendalar's Avatar
I have a little plumpy 205/55/16" on a 7" RIAL...soo, i think 225 tires would look a little...well odd..
Projects:
911 -72T EFI "964-look" "Smoky"
914 -71 1.7 D-JET "Rusty"
Old 02-10-2003, 11:35 PM
dd74's Avatar
How odd?
Gimme' a clue? Anyone?
Old 02-11-2003, 12:13 AM
Mikkel
Guest
Posts: n/a
Depends on what 911 you have. The factory used 7x16 wheels with 225/50x16 tires so 225/50x15 on 7x15 should be possible although they'd probably look better on 8x15. As for tire rubbing it depends on the model. It's my understanding that 225/50x15 can (or perhaps will) rub on early cars.
Old 02-11-2003, 03:38 AM
Somewhere in the Midwest
MotoSook's Avatar
205/50R16 is about the largest without custome offsets. I have 205/50 on 16" X 7" Fuchs in the rear od my narrow 76S and the left side rubs on the fender. Nothing a rolled lip wont fix.
Old 02-11-2003, 03:51 AM
MotoSook's Avatar
here's what 7X16's look like int he rear.
Old 02-11-2003, 03:54 AM
IROC's Avatar
I ran 225/50-15s on 7x15 Cookie Cutters on all four corners of my '76 911 before I added SC flares. The best advice I can give is to find someone with that tire and wheel combo and test fit them on your car. That's the only true way to know whether they'll fit or not due to the many variables involved.
FWIW, on my car I was running 22/29mm torsion bars and approx -1 to -1.5 degrees of camber all around and had also rolled the fender lips.
IMHO, the 225/50-15 set-up was the best performing set-up I ran before SC flares and I tried alot of things....
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 02-11-2003, 04:08 AM
SweetE's Avatar
I've run 225X50X15 Yoko A008RS on 6.5X15 minilites on a 73 911E with no problems!!
No spacers either.
Old 02-11-2003, 12:13 PM
jphillips-998's Avatar
I tried on a pair of 225x50x16's up front with no luck. It is going to depend on your wheel offsets.
Jeff
'04 Cayenne S Hauler
'98 993 Cab
'74 Euro Carrera - SOLD
'91 944S2 Track Car
Old 02-11-2003, 07:22 PM
