-   -   Remove Clock - Install CHT ?? (http://forums.pelicanparts.com/porsche-911-technical-forum/97878-remove-clock-install-cht.html)
North Coast Cab 02-11-2003 06:32 PM
Will the VDO Cylinder Head Temp gauge directly replace the factory clock?
JG
Doug Zielke 02-11-2003 06:43 PM
I'm wondering about this too...but I think the VDO gauge is much smaller in diameter than the clock.
cary 02-11-2003 06:55 PM
Way smaller . But someone makes a BIGASS oil pressure IDIOT light. That's what I think I'll do some day.
89911 02-11-2003 07:36 PM
Has anyone installed a direct air vent in the clock outlet? I know SmartRacing sells these for $200 and I am wondering what you get for the $$?
tryan 02-11-2003 07:51 PM
i think the vdo cht for 914's is a 2" and they sell a adapter ring to fit the 2 and 3/8ths hole in stock consoles. the 911 clock is 3" plus. modify fit!
maxnine11 02-11-2003 07:56 PM
you could do both. the oil pressure warning light (red lens), with the a cyl. head temp guage set into that lens. maxhttp://forums.pelicanparts.com/uploads/trbodashM.jpg
tryan 02-11-2003 08:04 PM
your knuckles are turning white at 125.
maxnine11 02-11-2003 08:08 PM
i stole that dash picture from Brian's Santa Barbara run pictures. looks closer to about 145. that's what color he always is !! LOL sorry Brian. max
tryan 02-11-2003 09:00 PM
i have the same winter tan.:) the dual purpose gauge looks excellent.
put a 6-way switch on + 5 more thermocouples and you could check every cylinder.
i have to take my clock out and shake it if i want it to start back up.
RallyJon 02-11-2003 09:06 PM
How about taking a fuel/oil level dual gauge and having one of the VDO gauge shops swap the guts for a CHT and maybe a voltmeter? Same diameter--would fit and look correct.
North Coast Cab 02-12-2003 03:39 AM
Wayne's got the CHT gauge listed as 2 1/16". I'll look into the custome set-up. Sure would be the easiest way to mount the CHT though. Unless of course Maxnine11 can fabricate the described idiot ligt and gauge.
JG
1980SC 02-12-2003 08:35 AM
I replaced my clock with the 2" VDO CHT gauge. I found that the plastic containers of cake icing/frosting fit perfectly into the clock hole. So after eating all of the icing, I cut a hole in the bottom of the container for the CHT gauge to slide into, and then cut off most of the length of the container. I think I wrapped some tape around the container for a snug fit into the clock hole. After some black spray paint, it looks factory to me.
I guess this adapter may not be for everyone, but it is cheap, and you get to eat a whole container of icing. Unfortunately, my camera will not take a clear picture any closer than this one.
http://forums.pelicanparts.com/uploads/cht8.JPG
-Rob
1980SC
maxnine11 02-12-2003 08:58 AM
mmmmmmmmmm....iiiccciinnnngggg!!
Bones 02-12-2003 11:05 AM
spare switches
On a similar topic , Does anyone have any useful suggestions for what to do with spare dash switches when they become obsolete...for instance since fitting a C2 bodykit I decided to lose the rear windsdreen wiper so that switch is spare
TimT 02-12-2003 01:12 PM
Check out these babies. Westach Will custom build you a guage, and then you can use the VDO adapter to install it in the clock opening. The prices arent to bad (if you get the non FAA certified gauges)
North Coast Cab 02-12-2003 02:56 PM
So I'll search for a donor gauge to build the adapter. It would be nice to keep the factory black bezel and glass and view the CHT gauge in the inside. Detail to follow.
JG
