Hi,
In looking at the heat exchangers my '73 911, I find that there is a pretty big gap ~1/8" between the exhaust pipes and the heat exchanger tin, all the way around the three exhaust pipes where the tin meets the pipes. This seems pretty inefficient for heating. Is this pretty typical for '73 vintage? -Juan
www.ArtOfRoadRacing.com, Thunderhill, 30 Jan 2011 ArtOfRoadRacing@gmail.com SM #34, '04 GT3, '73 911s, '70 911 2.7L PRC Toyo Spec #11 |
I just went out and looked at some old OEM units that came off a '73 and they have the same gap you report. The new SSI's which replaced them have a much tighter fit to a sleeve like cuff on the tin of the outer jacket. The OEM unit leaks some air but cheaper to manufacture (looser tolerances) and no concern about differential thermal expansion over stressing the joints. Cheers, Jim
Hi Jim,
Thanks for the info! -Juan
good ones fit the pipes snuggly. that's heat loss there.
Senior Member
While we're on the subject.....
I was told (warned?) just how much additional heat SSI's would provide. Well, kids...it's *true*. The cockpit is toasty-warm now like never before, and the heat comes on almost instantly. And this is with the back-dated heating system (no more electric blower), I installed when the motor was out.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
You do not have permissi
Hey Doug-still got that fan or know of a source for it? Thanks
