Fleabit peanut monkey
The emission requirements on your 78 vs that water cooled devil are night and day. Far less stringent on the 78. If you are hell bent on not springing for pressure gauges, the absolute core of CIS functionality ![]() There is one thing I will throw out here for grins. The deceleration valve on my 81 is designed to bleed air into the air box if you lift throttle at high rpm. The high vacuum opens the diaphragm. As rpm's decrease the diaphragm should close. I can put a golf tee in the small hose that feeds the unit and eliminate it from the system. Not sure if it's that simple on the 78. Your's is a little different.
1981 911SC Targa |
do you have the CO reading?
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
![]() These were the results from the test. |
![]() Minor hijack ![]() .
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Good news, its running great now. I replaced plugs, wires, dist cap, rotor and coil. Most seemed near original and well past their useful life.
Next up is the vacuum lines. I picked up a bunch of 3.5mm line but it looks like there are a few other sizes in there. I searched but couldn’t find a definitive chart of what else I’ll need. Does anyone know the other sizes? |
Vacuum lines. I snip 10mm of the ends and refit. It seems to work well. Another thing to do sometime is to replace the fuel filter.
I'm pleased the car is running well and you can get out there and enjoy it. It's a great looking car. |
![]() Time to pick up a fuel pressure gauge. Which one do you guys recommend?
1978 911SC - 3.2 1971 914/4 IG - @etcetera911 |
I am not sure if the '78 SC has this, but I had an issue with my O2 relay under the passenger seat going bad and exhibiting same symptoms on my '80 SC.
Here's a thread on it... with the part number that worked for me. (although if your relay has that plastic tab on it, you might want to order the other one on the page) Rough running and the green wire
J 911 SC - 1980 911 S - 1977 |
Not reliable! They are intermittent. Porsche factory only used a 3 pin unit (points ignition)
for one year and NOT for a 911SC.
Dave |
Intermittent problems that involve heat seem more like an electrical or ignition issue. The Permatunes are notorious for intermittent failures, although usually they require a bit of time to cool before they restart. If you crank and it doesn't start right away, get a timing light on it to see if you're getting spark.
Rutager West 1977 911S Targa Chocolate Brown |
Still here
Decel valve and O2 relay not present in the 78 CIS.
I was reading up on replacements for the permatune, it sounds like some people have had success with the MSD Streetfire. I’ve also read a bunch of complaints on the MSD, so I’m not sure if that’s the best route.
When it does die it’s when the clutch is in as I pull to a stop. From there it fires right back up and will run as long as I keep some throttle on it. I also noticed that it’s blowing a pretty large cloud when I first start it cold. Not sure if that’s related or normal. I know a little smoke is typical but this is like a solid 10ft radius. Blew it straight across the street this evening.
Hilbilly Deluxe
Ignition components doesn't seem like the right direction to me. I would expect if there really was a problem with the ignition, that there would be other symptoms.
What is your idle speed? Where is your timing set? Does your distributor have one vacuum line or two? I think the early SC only had one, for vacuum advance. |
I plugged the vac line that ran from the throttle body to the smog pump control (Diverter Valve?) because it was cracked and leaking. Ever since then it has a huge cloud of white smoke when I cold start. Makes me think that the mixture was rich to cover up for some of these vacuum leaks. Much of the parts on the motor are original. Is it crazy to consider just dropping the motor so I can easily replace all of the vac and fuel lines? Oh and your question about the idle, it seems a little high, hovers just above 1000 and occasionally will drop to 950. Distributor does only have one line. I'll have to check on the timing.
You have got to get all the vacuum / air leaks out of the system before you start doing anything else. Sounds like you have a lot of old rubber; old rubber splits and leaks, and with the sheer number of vacuum-controlled bits on these SC engines, you're chasing ghosts until you get real certain that all the air leaks are gone. Unmetered air can cause you to run lean, and if you adjust mixture while you have unmetered air, you'll be off again as soon as you fix the leaks.
There are some tricky leaks in hoses that run behind the CIS and fuel distributor. Also, check the rubber boot on your CIS and your airbox itself - those can leak too. Good luck! A smoke machine or a cigar can really be of assistance with this.
Jason - Austin, TX 82 911 SC targa (gone, but not forgotten) 92 968 coupe |
Haven't seen this asked/answered here - does RPM drop when you remove the oil filler cap with engine running?
My goal is to replace all of the lines. I purchased a bunch of 3.5mm line but it appears there are a bunch of different sizes. I couldnt find a straight answer on what I need to order. The next challenge becomes, how do I get to all the lines on the back side of the motor.
Hello There:
You can get to most of the smaller lines in the back of your CIS system by doing a partial engine drop. Hope this helps and Good Luck! ![]()
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
