-   -   I am making H5 to LED headlight conversions (http://forums.pelicanparts.com/porsche-911-technical-forum/979693-i-am-making-h5-led-headlight-conversions.html)
3Ddesigns911 12-03-2017 09:25 PM
I know this has been done already. I have searched what my options are, and decided to make my own H5 to LED headlight retrofit.
For the LED-s I have also been researching my choices and decided to go with the Nolden second generation bi-LED headlights.
Basically, this is what I am going to build.
https://en.noldengmbh.de/en/products/tuner-eng/44-unternehmen/tuning-news-eng/131-rpm-ncc-bi-led-hauptscheinwerfer-fuer-porsche-eng
I have already sourced the lights and imported the proper Porsche buckets, (so I don't have a small light bulb socket on the bottom) from Germany.
I thought since i am building one set I could build two if anybody is interested.
Let me guys know what you think.
Lund 12-03-2017 11:28 PM
i'd be interested in a set :)
mo-mon 12-04-2017 12:38 AM
I'm interested too. Thanks.
Pat RUFBTR 12-04-2017 01:33 AM
Hi,
Very interesting!
Difficult to have information in France by going on your link, do you know the price of these lighthouses?
rothaus 12-04-2017 04:42 AM
They Look great. Almost like mine.
http://carmagic.us/images/H4_LED-01.jpg
http://carmagic.us/images/H4_LED-02.jpg
http://carmagic.us/images/H4_LED-03.jpg
https://c1.staticflickr.com/5/4260/3...eaae6b75_b.jpg
https://c1.staticflickr.com/5/4226/3...b81e71fc_b.jpg
https://c1.staticflickr.com/1/263/31...bc5cee4e_o.jpg
Cheers
Engelbert
Bill Verburg 12-04-2017 05:07 AM
What's the current draw vs std 55/55 H4s
HorstP 12-04-2017 05:19 AM
please share how you build them. I already have the clear lenses but don't know yet exactly how to mount the GL-180 headlights
stf996 12-04-2017 05:28 AM
http://forums.pelicanparts.com/uploa...1512393760.jpg
Hello,
Long Time lurker from Oz.
Here are ones I made with Jeep LED'S 55 Watt (5 Amps) <$200 Australian including LED's, VW round inserts and clear glass.
Very easy, cheap and a huge improvement.
rothaus 12-04-2017 05:39 AM
These are 30W low beam, 48W high beam. The low beam stays on during high beam. They also have DRL/parking light function if needed.
Cheers
Engelbert
3Ddesigns911 12-04-2017 09:36 AM
I will be combining the back section of the H5 retaining bracket with the headlight holding section of the sugar scoops, essentially that is what holding the LED lights in place. Then we need to fabricate the parts to hold the bucket/lens/ring assembly.
I don't have all the pricing yet, and since the sugar scoop parts are going to be used (most likely) it will also depend on their cost, so that's a variable number.
FYI, I am not making this to be a cheap replacement. That's why I selected the Nolden, which is a premium light using OSRAM chips, comparable to the JW Speaker but more economical. I am also getting the buckets from Germany that does not have the small light bulb socket on the bottom. IMO the devil is in the details and since I'll be using clear lenses you can see what's behind it. Maybe the lenses are something to save some money on, I did find a set of clear Hella lenses for myself, but i think could go with the cheaper non-branded versions as well.
Anyway, I just wanted to though it out and see if I am making more than just my own set I could just as easily make another one or two the same time.
Let me know who's in and I'll keep you posted on my progress also.
froggert 12-04-2017 09:55 AM
Why use the H5 piece if you already have a headlight bucket?
famoroso 12-05-2017 11:52 AM
Such that he can use the H5's more secure mounting system a la what @Cook&Dunning did here... http://forums.pelicanparts.com/porsche-911-technical-forum/901604-h5-sealed-beam-headlight-conversion.html
3Ddesigns911 12-05-2017 11:56 AM
Exactly.
Sent from my SM-N900V using Tapatalk
froggert 12-05-2017 12:27 PM
Oh, I see now. Thanks for the link. That mounting and aiming should be much more secure and stable than the usual H4 method. Wish I'd seen that before converting my headlights.
7783911 12-05-2017 01:39 PM
i too would be interested in a set, i have the H$ setup now with Euro glass but to be honest prefer the combined scoop clear look
Bob
needspeed 12-30-2017 05:26 PM
Has anyone tried H5 LED bulbs as a plug-n-play replacement?
3Ddesigns911 12-30-2017 05:34 PM
Typically brighter bulbs don't make bad lights any better. They only make brighter light scatter all over the place.
The H4 design and good LED lights have much better patterns and sharper cut off. There is really no contest.
7783911 12-31-2017 07:53 AM
Light Set
PM sent
3Ddesigns911 04-11-2018 10:20 PM
I finally started working on my lights and realized I don't have enough of the ring retaining clips (springs), as well as the screws for the bottom of the rings.
I have a couple of questions also.
  • Are there specific locations around the ring where these clips have to go? How many do I need?
  • Also is the screw a specific one? i am seeing a couple of different versions, one with a plastic sleeve and one with just a longer neck.
This is what I have so far
Sorry about the bad pix, it was getting dark
LED light in a hybrid H5/Sugar scoop bucket.
http://forums.pelicanparts.com/uploa...1523510063.jpg
Light on low beam
The ring assembly is just hung on the car here. It's not actually screwed on yet.
rothaus 04-12-2018 04:42 AM
You need 8 clips, one on top, one at the bottom, and 3 left and right.
You should be able to use the same bottom screw you had in before.
Also, don't forget the rubber seal between the outer ring and the glass.
Cheers
Engelbert
