-   -   Rough Idle After Distributor Cap Replace (http://forums.pelicanparts.com/porsche-911-technical-forum/979758-rough-idle-after-distributor-cap-replace.html)
ausgezeichnet 12-04-2017 02:34 PM
Guys,
I just replaced the distributor cap and rotor on my 83 SC. Now it barely idles. Seems like is it missing a cylinder.
Fortunately, just before I replaced them I took the car our for a short drive an it ran fine.
I am sure I have the plug wires in the right spots on the cap because I labeled the wires took pictures before I removed anything and they also match order of the original yellow sticker on the car.
Is it possible for the cap to be rotated 180 degrees? If so, would that cause rough idle.
Mike
Litle brother 12-04-2017 02:45 PM
Hi Mike.
If I am not wrong the distributor cap only goes on one way.
But are you absolutely sure that the spark plug wires are all the way down in the distributor cap and well connected to the plugs?
Sometimes a bit hard to get the wires all the way in.
Sounds like you’re having a bad connection.
Just asking [emoji4]
Eskild
Bob Kontak 12-04-2017 03:27 PM
Like Litle Brother says check everything. No way on 180 out.
You did something simple causing the problem.
Especially if this was the only maintenance.
The spring clasp on the forward side of the cap is a stinker on my 81. Just saying.
ausgezeichnet 12-04-2017 04:27 PM
Thanks. That's what I thought. The wires are snug. They were not that difficult to remove or reseat so it was easy to make sure they were all fully seated.
ausgezeichnet 12-04-2017 04:29 PM
The cap seems to be seated firm I wonder if it could be a bad cap or rotor
Bob Kontak 12-04-2017 04:49 PM
1 6 2 4 3 5 counter clockwise. Nail this.
Norm01 12-04-2017 04:58 PM
Try putting your old rotor back in to see what happens.
big911fan 12-04-2017 05:00 PM
Check to make sure the rotor is pressed down on the distributor all the way. I had one once that was very tight and needed to be re-seated. Push down on the rotor to make sure it's seated then see if the cap seats any differently. After checking the firing order as above of course.
ausgezeichnet 12-04-2017 05:13 PM
Problem solved. The Distributor cap was not secure. Must have been that stinker clasp!
