ausgezeichnet's Avatar
Rough Idle After Distributor Cap Replace
Guys,
I just replaced the distributor cap and rotor on my 83 SC. Now it barely idles. Seems like is it missing a cylinder.
Fortunately, just before I replaced them I took the car our for a short drive an it ran fine.
I am sure I have the plug wires in the right spots on the cap because I labeled the wires took pictures before I removed anything and they also match order of the original yellow sticker on the car.
Is it possible for the cap to be rotated 180 degrees? If so, would that cause rough idle.
Mike
Mike
'84 911 Carrera Coupe (totaled)
'83 911 SC Coupe
‘06 Aston Martin Vantage V8
Old 12-04-2017, 02:34 PM
Hi Mike.
If I am not wrong the distributor cap only goes on one way.
But are you absolutely sure that the spark plug wires are all the way down in the distributor cap and well connected to the plugs?
Sometimes a bit hard to get the wires all the way in.
Sounds like you’re having a bad connection.
Just asking
Eskild
Old 12-04-2017, 02:45 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Like Litle Brother says check everything. No way on 180 out.
You did something simple causing the problem.
Especially if this was the only maintenance.
The spring clasp on the forward side of the cap is a stinker on my 81. Just saying.
1981 911SC Targa
Old 12-04-2017, 03:27 PM
Thanks. That's what I thought. The wires are snug. They were not that difficult to remove or reseat so it was easy to make sure they were all fully seated.
Mike
'83 911 SC Coupe
Old 12-04-2017, 04:27 PM
The cap seems to be seated firm I wonder if it could be a bad cap or rotor
Mike
'83 911 SC Coupe
Old 12-04-2017, 04:29 PM
Bob Kontak's Avatar
1 6 2 4 3 5 counter clockwise. Nail this.
1981 911SC Targa
Old 12-04-2017, 04:49 PM
Try putting your old rotor back in to see what happens.
Old 12-04-2017, 04:58 PM
Northern, CA
Check to make sure the rotor is pressed down on the distributor all the way. I had one once that was very tight and needed to be re-seated. Push down on the rotor to make sure it's seated then see if the cap seats any differently. After checking the firing order as above of course.
1989 Carrera Coupe
Old 12-04-2017, 05:00 PM
Problem solved. The Distributor cap was not secure. Must have been that stinker clasp!
Mike
'83 911 SC Coupe
Old 12-04-2017, 05:13 PM
