Tips on refurb - Pedal Cluster
Hello Braintrust!
I am in the process of rebuilding the pedal cluster on my ‘86.
Any advice on the best way to clean these up. Is having the cluster media blasted and powder coated a good idea?
It looks like some old tar like substance came off the floor of the car and stuck to the bottom of the cluster. Is there anything that I could smear/paint into the floor to build it back up?
Lastly, there are a few small dots of rust present. How aggressive should I go at it? Paint remover and then a wire brush? Or steel wool and then some rattle can paint? Any advice is appreciated.
Old 12-07-2017, 09:12 PM
Discseven's Avatar
GK... I like the idea of blasting and PC'ing cluster parts. Need to keep the PC out of tight tolerance areas. I'd do that to start with as opposed to drilling or filing it away after the fact. Would replace all plastic bushings with metal and lightly red grease those parts. Spring is obviously not to be PC'd. Since you're in the area, and if your clutch cable is old, good time to put new one in. Linkage cups... clean them out and light touch of red grease.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 12-08-2017, 05:03 AM
I powdercoated mine and really glad I did. Also went with the bronze bushings as Karl suggested. Definitely a worthwhile upgrade.
Have fun though, that project will test your patience.
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 12-08-2017, 08:36 AM
Counterclockwise?
I just wire brushed the rust off and hit it with some rust converter.
No down time this way.
Rod
1986 Carrera
2001 996TT
Old 12-08-2017, 01:12 PM
My pedal assembly was in pretty bad shape due to the clutch master leaking. I just wire brushed and painted it. Also change out the bushings and master cylinder.
1988 Carrera 3.2 Coupe
Old 12-08-2017, 02:51 PM
jamesjedi's Avatar
I have used aftermarket bushings and OEM. I found that the OEM bushings fitted better. I have only done it twice - others may say get the aftermarket.
Old 12-08-2017, 03:41 PM
I want to replace the brake spring as well as the clutch spring.
The only brake spring I can find from our host is Part #: 901-423-531-00-OEM
Will this work on a 1986 pedal cluster? 1986 is not listed as a viable year.
Also, can anyone direct me to the small rubber ring that is the throttle return stop?
Old 12-08-2017, 09:02 PM
Can’t seem to find these two on our host.
Old 12-08-2017, 09:11 PM
steely's Avatar
I think the first item is 90142319300 and the second item might be 91142339102 but check it out first.
PP seems have'em, but use google for a picture.
Do you have the PET katalog (parts list)? it's a great resource for parts identification.
go here https://www.porsche.com/usa/accessoriesandservices/classic/genuineparts/originalpartscatalogue/
scroll down, enter your model/year, and DL the pdf for free.
edit:
on the spring I got 911-423-531-03 but it comes up as NLA.
I can't say if the turbo ones are equivalents. (I have an 87 (G50) so mine may be different.)
http://www.pelicanparts.com/catalog/shopcart/101P/POR_101P_911040_pg3.htm
If it isn't rusted or damaged you may be ok.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 12-08-2017, 10:36 PM
Sand blared, POR 15 paint, bronze bushings. 1+ on no downtime waiting for others.
84 911 Targa Carrera currently getting renewed
Old 12-09-2017, 04:54 AM
jamesjedi's Avatar
Replace the bushings while it is out. The spring can be tough to pull back into place.
Old 12-09-2017, 05:20 AM
Thanks for all the support. I’ve got new bronze bushing and rubber stops coming. I’m leaning towards painting it myself. I’m in North Dallas, anyone know of a shop that would let me media blast the parts? I don’t have a media blaster, myself.
Old 12-09-2017, 05:58 AM
