-   -   Part Identification/Size Help (http://forums.pelicanparts.com/porsche-911-technical-forum/980926-part-identification-size-help.html)
Ferg911 12-16-2017 09:21 AM
Hey Everyone
New to the thread and this is my first post. I have a new (to me) 1986 911 that is giving me some electrical fits. Upon some inspection, I found a fuse blown and melted in the holder. I believe that this fuse is for the rear license plate lights. I cannot find the replacement part or the size of the replacement fuse anywhere. Any help/guidance would be greatly appreciated.http://forums.pelicanparts.com/uploa...1513444823.jpg
JRSIII 12-16-2017 09:47 AM
I can't tell exactly what fuse you are referring to, but red is 16A, yellow is 5A, and white is 8A. You can buy an assortment at Autozone or order online from Amazon. The red one on the end is for your fog lights. The yellow one next to it is for license plate lights, headlight and fog light switch illumination, and rear fog light if you have one.
Ferg911 12-16-2017 10:19 AM
I'm referring to the Inline fuse holder marked with a "K". The glass fuse hanging out of it is melted to the holder. Looking for the proper fuse size and where to get a proper replacement for the holder
JRSIII 12-16-2017 10:22 AM
My bad. Sorry. Can't help with that one.
proporsche 12-16-2017 10:23 AM
ferg ....the fuse you are looking for is easy to find in any by electronic store...
Ivan
Joe Bob 12-16-2017 10:25 AM
Do you know what device it supplied power to? I would cut it out out and do an autopsy with an exacto blade....
JJ 911SC 12-16-2017 10:25 AM
Not an OEM part so you need to be sure what it was powering before guessing the rating.
proporsche 12-16-2017 10:28 AM
it is for the rear licence plate light boys..;-) ferg911.. if they are still in biss you can get it in Radio shack,maybe Frys and pep boys..?
Ivan
Ferg911 12-16-2017 11:00 AM
Appreciate the help thus far.....here is what I am turning up when I am searching online:
That fuse is OEM for the rear license plate lights for 1986 (It is marked on my fuse schematic) but the amp/size isn't noted anywhere. Since it is toast, I have no way of finding what size to replace it with. I am also having a hard time finding a replacement holder (or would ANY fuse holder suffice)?
Please let me know if anyone else has run into this
proporsche 12-16-2017 11:13 AM
any fuse 5-8 A will do for the lights.Also any fuse holder for this or other kind of fuse will too...if you do not have the original..btw what happened to it?
Ivan
HaroldMHedge 12-16-2017 11:37 AM
The fuse amp rating should be embossed on the side of the metal fuse ends. Similar to these: Auto Glass Fuse
I think these are the correct numbers for the fuse holder assembly:
Fuse Holder 928-612-479-00
Lock 900-321-004-90 (Edit: I got this part number from a PET but searching online it comes back as a 2.5 amp fuse.)
Ferg911 12-16-2017 11:45 AM
I don't know. I think I have a ground issue somewhere. Trying to figure it all out systematically. Very new to all of this so I'm sure I will be leaning on all of you for help.
Ferg911 12-16-2017 11:53 AM
Thanks Harold!!
louielargo 12-16-2017 11:58 AM
I checked the 86 Carrera im working on...
It's a 2.5 Amp/250 Volt fuse.
http://forums.pelicanparts.com/uploa...1513454210.jpg
Good luck.
Cheers, Louie
HaroldMHedge 12-16-2017 12:14 PM
You should have a fuse card (911.612.243.02 for 86) fitted to the cover.
I found a photo of this on the Sierra Madre site (Sorry Pelican Parts) and as Louie said it is a 2.5 amp fuse.
Edit fuse card number should be 911.612.243.00.
JJ 911SC 12-16-2017 03:29 PM
Originally Posted by JJ 911SC (Post 9851038)
Not an OEM part...
That fuse is OEM for the rear license plate lights for 1986 (It is marked on my fuse schematic)...
I stand corrected.
I wish this was a working day because when you learn something, you can go home :)
Ferg911 12-17-2017 07:13 AM
Thanks Louie! Thats the info I was looking for :)
steely 12-17-2017 08:28 AM
cool - first time I've seeing a holder like that!
