Turn signals
So my car 1972 911 is pretty old, right? Now the left turn signal gets loose and doesn't make a good contact. I won't go into all the little tips I tried for a better contact.
I talked to someone the other day and he said,"are you using metric bulbs?". What? Is that something available? Maybe they'd fit tighter?? Well???????
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
ROW '78 911 Targa
Apply solder to the lengthen the contact tips of the bulb yet?
Worked on mine.
FWIW, I have a similar issue with my "newer" 1973. A bit of tin foil helps.
ROW '78 911 Targa
I'll try some solder today, thanks
Functionista
Are your prongs secure or do they move back with a light push?
A common issue is the tabs holding the prong base which contacts the bulb get weak or corroded. So you push the bulb in and no contact. The cure is removing assembly and drilling a 1/16” hole in tab post and base in order to safety wire prong base securely. Sounds confusing but it’ll all make sense once you get housing out.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
I think I did years ago try the solder routine but maybe I didn't put enough on them. The comment about the metric size go me to thinking because the bulb doesn't fit tight. The contacts do push in hence my thought that there really is a correct size. Wonder if the owners book or my shop manual addresses the correct bulb size, hmmm.
For the rear turn signal, the Porsche Part in the Pelican parts is # 900-631-128-90-OEM. The picture shows a 7528 of which a 1157 is the closest American equivalent.
Try to get a 7528. A well stocked Autoparts store may have one. I found the one for my BMW at Knencts.
