Battery question
Thinking of changing my battery. Any suggestions on the best battery for an 84 targa? What do fellow pelican have?
Old 12-23-2017, 06:46 AM
I went with the odyssey 925, it fits in the smuggler box and reduced weight a lot
Ächtung Kraft Founder - Custom Porsche Parts and Leather
http://achtungkraft.com - Bryan Rasch - bryan@achtungkraft.com
INSTAGRAM // @AchtungKraft // @BrightonRennsport
1972 911 ROW Steel Wide body Outlaw w/'86 turbo drivetrain
1976 911S + 2006 911 4S + 2009 Cayenne GTS + 1988 944
Old 12-23-2017, 06:49 AM
Franks89-911's Avatar
I chose an Absorbed Glass Mat (AGM) from Advance Auto Parts. H6 size, which I think is one step smaller than the H8 my '89 calls for. Advance has a 20% online discount, and you can order it online and pick up free in store, so I think I paid around $140 for it. It's been a great battery.
Frank
1989 911 Carrera Targa 3.2L, all stock
78k miles (as of Dec 2023)
"The Machine"
Old 12-23-2017, 07:04 AM
I did the same 3 years ago and have seen no downside to the battery downsize -- the battery tray even has a pre-drilled/tapped hole for the h6 bracket position.
Old 12-23-2017, 08:23 AM
Eng-o-neer
Tremelune's Avatar
Why do you want to change your battery?
The fact that lead acid batteries can leak means they're not worth the cost savings to me...Lots of AGM and Lithium options out there. In terms of weight savings for a small battery, it's equivalent to a few gallons of gas, and it's in the front where you want it anyway.
In any car, if you don't start it below 0°F, you can cut the cold-cranking amps spec (and thus the size of the battery) in half without affecting the starting capability. You can do this again if you don't start the car below freezing. I wouldn't worry about brands too much—in the US, they're all made by the same 3-4 companies. I have an Odyssey PC925 and it starts my 3.6 with gusto, even below freezing.
Whatever battery you go with, put it on a tender if you don't drive it every few days. It'll last a lot longer, and good tenders are $25.
Old 12-23-2017, 09:08 AM
I think people tend to overthink this. A Duralast Gold or Die-Hard H6 will work fine. Volts are volts and amps are amps. The battery doesn't know or care that it's in a Porsche, and the car doesn't know what brand the power is coming from!
Old 12-23-2017, 10:16 AM
Eng-o-neer
Tremelune's Avatar
While they will work fine, there is a reason every classic car buying guide says "check for rust under the battery."
Old 12-23-2017, 10:18 AM
I agree, however whatever brand you use, don't select a flooded cell
battery, they are rust and corrosion creators. The modern AGM Absorbed Glass Mat batteries don't leak and you can even use them side ways or upside down! Plus they are not that much higher priced and last longer than flooded cell batteries.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 12-23-2017, 10:46 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
And a gallon of highly concentrated sulfuric acid sloshing loose is just... a really bad thing to have in a metal car that you want to preserve. Especially one that goes around corners, accelerates, and stops with some vigor. The steel doesn't care whether it's a Porsche or a Vega when the acid arrives.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio
Old 12-23-2017, 12:14 PM
