Needed - Removal tools for 915 Dog Teeth
Anyone in the Annapolis area have the tools I can borrow for a few hours? Figured I ask before I buy a tool I will most likely use once, lol. Need to pull 1st-4th rings. Pm me if you can help out.
Old 02-18-2018, 11:36 AM
Under the radar
Trackrash's Avatar
If you don't plan on re-using them, cut them off with a drimmel.
I used one of these "bearing splitters".
Gordon
'71 911 Coupe 3,0L outlawed
Old 02-18-2018, 05:49 PM
Thanks. Yeah I’m not reusing 1st. The remainder will be removed and most likely reinstalled as they are in good condition. I have some various pullers but wanted to give this a shot first before moving forward.
Old 02-18-2018, 05:53 PM
Why pull off the good ones? Not logical.
206 637 4071
Old 02-19-2018, 04:17 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Yep if they're in good condition, there's no reason to pull them off because you're disturbing the press fit and the "peening" that is done at the factory to secure the ring to the male cogs on the gear
Kevin L
'86 Carrera "Larry"
Old 02-19-2018, 06:28 AM
Habit I guess. The box everything came out of was pretty funky so pulling everything apart to clean/inspect made sense. I have a set of new ones coming to compare the old ones too. They don’t appear to be blunted over. But if I decide to replace they already have been removed.
Old 02-19-2018, 06:32 AM
ganun's Avatar
Support the gear by the ring then Carefully heat the ring . The gear will fall out by itself.
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 02-19-2018, 06:54 AM
Really?
206 637 4071
Old 02-19-2018, 10:57 AM
proporsche's Avatar
Hi Toco..
the rule applies here..." if it ain`t broken why fix it....."
One oldtimer 911 mechanic once showed me how to remove the dog teeth-rings..simple -hammer and nice sharp chisel.The ring will pup out easy.
If your other dog teeth are ok do not bother with them as John W.said
George..
no way you should heat up the dog teeth`s while on the gear.This only apply on installation procedure.
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-19-2018, 11:27 AM
Hubs have been removed. Thanks to everyone for the advice.
Old 02-19-2018, 12:27 PM
Mark Salvetti's Avatar
So how did you do it? My long story is that I have new dog teeth on 1-4 that were installed a few years go, but the box was never assembled. Now I've decided that 1st-3rd gears have wear and should be replaced (I've procured replacements).
I need to remove the brand new dog teeth without damaging them so I can re-install them on the new gears.
Do I need to worry about this if I use the proper tools?
Mark
1979 911SC Targa
Old 02-19-2018, 01:54 PM
