Elombard's Avatar
Fastener engineers - need some confirmation
I have B&B headers on my 3.2. The lower valve cover cannot be removed due to clearance, I think most folks shorten the lower valve cover studs a little so they can be removed.
I was thinking of replacing the studs with cap head bolts.
Is this a good idea? Is there any issues with the heat and cool cycle that these will see?
I dont want to go with ARP or something $$$ just decent quality available locally.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 12-27-2017, 08:27 AM
Once a friend of Cliff
juanbenae's Avatar
I suspect the torque value need for the valve covers is significantly less than a simple bolt will provide w/o backing out. the torque on the VCs is low to not cause warp-age hence the fresh nylocks with every gasket kit. maybe the lightest (green? blue?) thread locker would aid in keeping the torque w/I range and lessen the backing out opportunity? usually a little heat will free up the lighter thread lock compounds.
Old 12-27-2017, 09:42 AM
Elombard's Avatar
ahh Its the nylocks that are the key.
I bet you are right a regular bolt will not stay torqued at the light load.
I will consider the light thread lock.
thx
Old 12-27-2017, 09:48 AM
juanbenae's Avatar
before you run out and by thread lock maybe wait until someone smarter than me chimes in.
the only other thing I would consider is possibly some of the single use schnor (SP?) washers that are so prevalent on these cars. thing is with the covers being aluminum any regular lock washer might gouge them significantly. they are often used on low torque bolts that will affix to aluminum.
Old 12-27-2017, 10:08 AM
peon77's Avatar
you could replace the studs, there are cap head bolts with a nyloc insert but you would have to heli-coil each hole that gets a bolt.
75 911s
86 951 sold to make room for baby seat
09 335i 6MT
NVH
Old 12-27-2017, 10:27 AM
Elombard's Avatar
eeew dont want to go to that much trouble
Old 12-27-2017, 12:11 PM
walt's Avatar
A drop of blue loctite. Medium strength but removable with hand tools.
Walt
82SC 3.0
81SC 3.6
Old 12-27-2017, 12:37 PM
Elombard's Avatar
What class of bolt should I look for? Just something in mild steel to match the expansion characteristics of the stock studs?
Old 12-27-2017, 04:49 PM
(man/dude)
Jonny042's Avatar
Just thinking out loud, but drilled heads on allen head bolts and safety wire could work too.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 12-28-2017, 06:56 AM
Harpo's Avatar
studs in to aluminum
Because the stud is threading in to aluminum and most import because this is a serviceable joint please don't use a bolt. Yes please use nylon lock nuts. Please don't use a schorr washer on aluminum. I also like blue locktite.
I don't know the grade of the fasteners in question but here is the rule of thumb that I utilize when ever designing fastener joints in to aluminum.
Grade 8.8 require a minimum of 1.6 x diameter of threaded engagement in to aluminum
Grade 10.9 require a minimum of 2.0 x diameter of threaded engagement in to aluminum
Hope this helps
Old 12-28-2017, 07:10 AM
faverymi's Avatar
I would stay with nylock nuts raher than messing the threads in the cam carriers
I wouldn't re-invent the wheel. When needed I remove the headers for access
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 12-28-2017, 07:15 AM
Elombard's Avatar
Right no not going to touch the threads, I was going to use a bolt that is the same size and thread as the existing stud but shorter so I could remove it with out removing the headers.
Old 12-28-2017, 09:49 AM
What about trying a M8 half height nyloc nut?
Edit
I believe these nuts should be grade 8 from the factory.
Old 12-28-2017, 10:03 AM
Not much effort to try it if the valve covers are off. Be aware that some of the stud holes run through to the rocker chambers. I would try a flange head bolt with a rubber or plastic washer to seal.
edit: Just checked some cam carriers in the shed and all the holes were blind, guess I got lucky with ones on my car as the lower row of studs are not blind. Easy to check if your VCs are off.
Old 12-28-2017, 10:38 AM
Harpo's Avatar
I don't recommend it
Old 12-28-2017, 11:09 AM
gtc gtc is offline
abides.
gtc's Avatar
Never heard of people having problems removing the valve covers. I did a few valve adjustments with B&B's on my car and don't remember any particular difficulties.
Graham
1984 Carrera Targa
Old 12-28-2017, 03:46 PM
You can buy some set screw style studs that have an allen head top. Then you can still use the nyloc nuts. When you need to remove valve cover just remove stud with allen wrench.
Old 12-28-2017, 05:15 PM
Just use a damn bolt w/aluminum washer and check them once in a while. Jeeze. Just need a few along the bottom. That header design sucks for clearance to the V/C studs, making an easy job a bittch.
206 637 4071
Old 12-28-2017, 05:28 PM
MConn's Avatar
Just a guess, can you add a gasket or 2 at the header-to-head flange to get the header away from the valve cover?
I'm going trough a fitment issue with M&K headers-to-bumper right now, so i feel your pain.
Mike
The more I learn, the less I know.
Old 12-28-2017, 05:39 PM
Elombard's Avatar
Thanks John
I don't want to remove the headers at the moment if I don't have to.
Old 12-28-2017, 06:14 PM
