Pop and now No Start
Took our 1983 911SC to the hardware store and she ran great like she always has. Never a cough or a sputter from the 105K mileage 3.0L. Always runs flawlessly.
Parked her for 90 minutes and then went to continue some errands. While starting she popped and now won't start. The engine ignites but doesn't continue to run. The"pop" was not a loud back fire, something much less, but definitely a "pop". Let her sit for a while and then tried again, same scenario. Not sure were to start the troubleshooting. Any ideas?
1983 911SC 1954 Rolls Royce Silver Dawn |
I would poke around the engine compartment to make sure all connections are secure. Also, swap the fuel pump relay with a another one in your fuse panel.
Banned but not out, yet..
Remove the air cleaner and filter to see if your pop off valve is stuck open, if you have one. It may also have blown out of place and will need to be secured back down until it can be epoxied.
An air cooled refrigerator. ‘Mein Teil’ |
Check that the pop off valve in the air box is seated..... if you have one.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Checked out
You have a vacuum leak somewhere.
Probably blew the box if there is no pop-off. Hopefully the pop-off is just popped and not closing, if not you probably smoked the plastic box.
We can't just throw around worst case $$$ scenario conjecture here. For one, a small "pop" noise from the intake does not indicate a blown air box. That would be a "bang!" Even then that wouldn't automatically lead to a cracked box. The OP needs to pragmatically go through the motions of checking the easiest and most obvious first.
Pop-off valves pop out all the time. May just need a reglue.
Thank You -
Yes indeed, the pop-off valve has separated from the air box. Now time to re-epoxy and evaluating whether or not this can be done with the air box in place. Thanks for the diagnosis.
When I did mine, I left the old epoxy in place to act as a template to hold the valve.
Still here
Not sure we can conclude the toilet seat is the definitive cause of the backfire.
The backfire typically results from a lean mixture that denotes suddenly. The flapper valve popping out is the symptom and results in the car not running due to the massive amount of unmetered air from the popped out flapper.
