wheel question
getting ready to clean up a pair of 15 x 8 fuchs I've been saving for my race car
the date stamp is: 1176 are these from a Carrera 2.7 most likely? most of the 8's I've had in the past were 944 wheels with date stamps in the 80's so I was just curious don't intend to sell them thanks for the info I need to measure the center caps and haven't done it yet brant
914/6 2.0S with twin plug all metal body panels 19quarts of oil 4 gallons of gas and 1826 lbs (wet) |
Vintage Owner
Could they be from a 930? That sounds correct for the rear wheels back in the day.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
what's the part number?
Are they possibly 15"x9"s ??
max |
they are stamped as 8J x15
I found the part number on this list: (last part number for 8's) 7x15 12 23.3 112 911.361.020.41 7x15 12 49 (911R) 138 901.361.012.05; allows larger tire on narrow body 911s 8x15 14 10.6 112 911.361.020.42 / 911.361.020.12 9x15 ? 3.0 117 911.361.020.03 / 911.361.020.06, still... as a 76 build year... I'm curious I will need to measure the center cap opening does anyone know what year they went to the ring style center caps? tia brant
That wheel was used on '76 Carrera 3.0, & 930
It has a large hole ring type ctr cap
Thank you !
