WP0ZZZ's Avatar
Fixing 915 of Euro-spec MY80 SC
This morning I test-drove an Euro MY80 SC and the gearbox felt very far from perfect. I would like to share the symptoms with you and I would be very grateful to know your thoughts on how hard it would be to fix them.
1. Lever moves freely right and left from neutral. No "springiness" as one would expect in a manual gearbox.
2. Moving the lever into first gear I didn't feel any mechanical feedback to tell me that I was in gear. In other words, the lever slides into position and stays there but there is no tiny vibration in the lever like in most gearboxes to suggest that the lever has moved through the point at which the gear is engaged. Hard to explain the feeling. Hope that you kind of understand what I mean.
3. Second gear engaged pretty well both upshifting and downshifting. Third gear was a bit of a pain in the ass. Hard to engage when upshifting.
Old 02-01-2018, 10:35 AM
Sounds like bushings and shifter alignment. Maybe the swivel bushings in the back seat access are gone, it is almost 40years old.
Bruce
Old 02-01-2018, 10:43 AM
Peter Zimmermann's Avatar
WPO; have a 915 expert, if you can find one, drive the car. 915s are a different animal, and they really can't compare to other manual transmissions that you might have driven in the past.
3rd gear upshift is a concern, how many revs were you using when you encountered difficulty?
Keep the Shiny Side UP!
Pete Z.
Old 02-01-2018, 11:05 AM
WP0ZZZ's Avatar
Would this cause the lack of lateral self-centering around neutral?
Unfortunately I don't know any 915 specialist in my area.
I was doing the upshift to third at low revs, around 2-3k.
Old 02-01-2018, 12:44 PM
self-centering around neutral sounds normal -- my properly set up 915 has freeplay with no centering between 1st/2nd and 3rd/4th) but has a spring resistance between 3rd/4th and 5th/reverse. So, I slap left to find 1st and second, push right (but not hard against spring resistance) to find 3rd/4th and then keep pushing right through spring resistance for 5th/reverse.
Usual 915 issues include a) worn/dead 1st gear synchros, b) worn 2d gear synchros that will crunch a bit on 1st to 2d shifts.
Old 02-01-2018, 12:54 PM
Bill Douglas's Avatar
Sounds quite good to me.
I'd renew the coupler, put in sport engine and transmission mounts and change the gearbox oil.
Old 02-01-2018, 01:52 PM
Darrin
Having spring pressure to the left in the shifter, sounds like your shifter is a earlier shifter.
You’re suposed to have spring pressure to the right for fifth and reverse.
Bruce
Old 02-01-2018, 02:10 PM
Darrin
Bruce
Bruce -- I think we're saying the same thing (but you said it more eloquently) -- push through spring pressure to the right when engaging 5th/reverse, no spring pressure between/among the first 4 gears.
Old 02-01-2018, 03:43 PM
gearhead
Yeah, you don't want to do that. Engine doesn't even make peak torque until over 4000. Next time you drive one make sure that both the 1-2 shift and 2-3 shift are at or above 3500. There's no sound argument to shifting any lower.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 02-01-2018, 04:18 PM
WP0ZZZ's Avatar
Cool. So that clarifies that the behaviour I observed was to be expected.
If I end up buying the car I'll make sure that I don't change below 6000
Old 02-01-2018, 04:31 PM
gearhead
1974 914 Bumble Bee
2009 Outback XT
Old 02-01-2018, 04:44 PM
WP0ZZZ's Avatar
I'm still wondering if the "problem" number 2 is something to be expected in a 915 gearbox or if it's due to an issue. Any ideas?
Old 02-02-2018, 08:52 AM
Josh D's Avatar
The coupler bushings and the cup bushing in the shift rod below the shifter would need to be inspected and found in good shape before problems with the transmission are assumed. I understand that makes purchasing the car more of a risk, but these bushings are known issues with shifting feel and problems related to these cars.
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 02-02-2018, 09:02 AM
