Question Converting to H4's from a later model
We are in the process of converting the original headlamps of an 87 (H5's?) to earlier H4's. Apart from the headlight bucket themselves, a different wiring plug for the bulb itself is needed also. Is this sold as a different item, and if so, what Item number for ordering. Thanks.
Old 02-16-2003, 10:26 AM
Pre Registered
tchanson's Avatar
Are you referring to adapter kit for the plug itself? If so, AJUSA sells a simple kit for converting from H5's to H4's. (I'm unaware if Pelican sells anything comparable...)
Good luck,
Tim
Old 02-16-2003, 12:53 PM
Tim, yes that is what I need. I was hoping something was available instead of cutting and soldering a new plug on. Thanks.
Old 02-16-2003, 03:09 PM
