Valve adjustment secret.
Is this the secret to adjusting the valve: there is no perfect drag?
Tell me if this makes sense to you. Slide the feeler guage in, then try to rock the rocker back and forth. It should not move. If it does, it's too loose. Tighten up until you can move the feeler around, and the rocker can't be rocked back and forth. Remove the feeler, now you should be able to rock the rocker back and forth a bit. If it doesn't, it's too tight. The problem with the relying on the feel of the drag is that the drag will change if the angle of the feeler blade changes. ----- anthony |
The drag will also change if you run mobile one, are you using a feelers guage or are you using the actual tool for this, yea there is about an 1/8 turn that makes a difference, Kevin
the angle of the gauge shouldn't be changing. you don't reef the gauge all around, you must keep it on the same plane as the tip of the valve. use a twisting motion to work the gauge in and out. 2 or 3 twists in or out, with no slipping and you've got it. if the gauge can be slipped in/out, then it's a hair too loose. if it's too tight, the gauge will get all bent up, or torn.
sounds like i may have my valves a hair loose, will it hurt anything John?, Kevin
Team California
Absolutely not. But I'm not John. But that's what he would say.
Denis |
I may be mistaken but I think it would be better to be a hair too loose than a hair too tight though they may make a little more noise loose. Though my experience is more w/ BMW motorcycle airhead motors I suspect they're quite simular in this respect.
John, please correct me if I'm wrong. Bill W.
Bill W. '97 Arena Red / Gray 993 Cab '93 968 Coupe 6 Spd '88 911 Cab Red/Blk (sold) |
Senior Member
Be sure your exhaust valves are not too tight. Too loose is safer, but it causes more valve noise (ticking) and can make the car lurchy in parking lots. As John said, there should be some drag on the feeler gauge, but not enough to tear it, or make it impossible to wiggle-insert. It's a fine line. WAY, WAY finer than 1/8 turn. When adjusting, carefully watch the positon of the slot, and move it just a TINY bit at a time. 1/8 turn can take it from way to tight to way too loose.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
most of my feeler gauges have miked out at .0042-.0044.....understand that.
--Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
news to me.. reads like great info.. thanks
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Doesn't anyone use one of the dial gages to do this?
Paul 2001 CLK55 AMG, 1987 911 Turbo Look, 1997 Viper GTS. |
Senior Member
I use the dial gauge method and I like it much better, though it burns more time. Most folks prefer the feeler gauge method, including many who have tried both. I understand their feeling too. But I do like the dial gauge method best for myself.
Formerly bb80sc
I have found a trick that works pretty well, but perhaps someone can chime in to tell me if it's ok or not.
I leave the gauge in there and tighten things up a bit. Then, I continue to micro-tighten the nut and feel the resistance of the guage as I wiggle it. Don't know if this is good or not because the adjusting screw still moves ever so slightly as I tighten the nut and get the final adjustment. Does this make sense
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
Senior Member
That method will cost you some feeler gauge blades. For the most part, feeler gauge or no feeler gauge, if it is loose I carefully note the exact position of the screw slot, and adjust that. With the screwdriver engage for feel, I loosen the jam nut, but not all the way. Usually the screw does not move. Then, with the jam nut making pressure on the screw, but very little since it has been loosened, I turn them in the direction I need, together. Just a tiny bit. Then I hold the screw steady while tightening the jam nut.
I've tried the dial indicator method. If the engine is in the car, forget it. No room for the indicator and base on most cylinders.
To learn the right drag feel, set a caliper to .004 and slide your feeler guage through it. That is how it should feel.
Chuck Moreland - elephantracing.com - vonnen.com |
Dito to what Chuck said.
Senior Member
So far, I really haven't read any "secrets" here.
But it's no secret that the island911 Valve Adjustment Tool (tm) almost makes the job a pleasure. And as accurate a setting as you can get!
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
Formerly bb80sc
Indeed, the Island911 (tm) tool is terrific and that's how I am able to adjust the valves as indicated in my post without breaking blades
Best tool I have purchased to date.
What's the Island911 tool? Havn't heard of that one.
Rick '76 Carrera 3.0, track '77 3.2 targa, back home '95 993 C4 M030, SOLD PCA San Diego |
better valve adjust tool
Great story, I'm going to get one of those for my future valve adjusts.
Ron, Thanks for the link Rick
