marcesq's Avatar
Question Engine ID help
Amidst almost 2' of snow, I found time to play.
Can anyone help with this engine number: 6311450.
Thanks in advance.
Gone snow shoveling
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 02-16-2003, 10:01 AM
nick-moss's Avatar
1971 2.2S, 180 bhp
Nick Moss - RGruppe #318
early911.co.uk
Old 02-16-2003, 10:11 AM
Amazing oversight on Porsche's part - they repeated a series of engine numbers they'd already used 10 years previously !
6311450 can also be a 1981 ROW 3.0SC
Andy
'69 911E---------->R
Andy
M&W 904 ... now gone
GT-style 356C ... also gone
Old 02-16-2003, 10:29 AM
nick-moss's Avatar
I think it would be difficult to mix those 2 up!
early911.co.uk
Old 02-16-2003, 10:34 AM
marcesq's Avatar
Ok . . . the above begs the question, both the 2.2 and 3.0 have red cowling right??? How do we tell the difference??
Forgot to say the engine has 40ida 10s on it so I can't tell based on the induction system.
Old 02-16-2003, 10:35 AM
nick-moss's Avatar
2.2 has MFI (vertical throttle bodies), mag cases
3.0 has CIS injection (curved alloy throttle bodies), aluminium cases
Sorry, wrote this before you edited!
early911.co.uk
Old 02-16-2003, 10:40 AM
nick-moss's Avatar
You need to look at the casting numbers on the cases
the 3.0 has a 930 number I believe
early911.co.uk
Old 02-16-2003, 10:44 AM
marcesq's Avatar
Are Mag cases black on the underside??? Can't remember from my 2.7
Old 02-16-2003, 10:45 AM
nick-moss's Avatar
mine aren't
early911.co.uk
Easiest way to determine which of the 2 engines it is will be to check the engine type number (on flat horizontal part of the crankcase to the rhs of the fan) - '71 S engine is 911/02, '81 SC is 930/10
Andy
Andy
Old 02-16-2003, 10:53 AM
marcesq's Avatar
Thanks guys. I'm leaning on the engine being a 2.2. No updated valve covers, no oil fed tensioners. My guess is that if a swap was done that stuff would have been done.
In addition the vin is 9111310586.
Old 02-16-2003, 12:16 PM
marcesq's Avatar
Andy
I'm guessing that Porsche figured that if you can't tell the difference between the two, then it wouldn't matter much. After all 180 hp is 180hp right
Old 02-16-2003, 12:45 PM
