Intermittent wiper switch help
Any suggestion on how to install a replacement for broken intermittent wiper knob? Just received a replacement from Ebay.http://forums.pelicanparts.com/uploa...1516146559.jpg
http://forums.pelicanparts.com/uploa...1516146559.jpg |
Pull the clock if you can get your hand through the opening, or the speedo, so you can disconnect the wiring. Grab the wire from the back with a hemostat or something to keep it from escaping into the abyss. I bet the black plastic top just pops off and has a ring style nut to tighten.
When you remove any instrument, make a diagram of which colored wire goes where. |
Thanks Bob. I’ll give it a try.
| All times are GMT -8. The time now is 08:25 PM. |
