Electrical question: Does this look right
78sc. Positive battery cable and s a bit warm.
Old 01-21-2018, 11:51 AM
old man neri's Avatar
It could have been caused by the really dirty state of the connections. Hard to tell until you take it apart and inspect/clean it. But yes, it looks like something got warm.
Old 01-21-2018, 12:06 PM
Platinum Member
dad911's Avatar
Clean it up and replace rusty and pitted parts. Current through resistance = heat (and voltage drop) P=R x I^2 (power loss (heat) = Resistance times current squared.)
Old 01-21-2018, 12:22 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Whatever dad911 says if you understand it.
What I would do it clean up and replace rusty and pitted parts.
I believe that goes back to the starter. Check connection there and make sure your ground to body from battery is robust.
1981 911SC Targa
Old 01-21-2018, 01:20 PM
Undocumented User
McLaren-TAG's Avatar
Is that red wire leading off to the relay kit fused? It seems like it's taken the worst of it and unfused connection will draw a lot of current and overheat whereas the fuse would have simply popped.
Clean it up and follow the wires to make sure nothing else is overheated and burned the insulation off.
Old 01-21-2018, 01:59 PM
Jonny H's Avatar
Undo those ring crimps and clean back to shiny metal. The red and black wire 'additions' look too far gone. Cut back to shiny wire and recrimp. Replace the rusty clamp bolt too.
If the red wire is the feed for a the headlight relay kit, it should still be fused by the original headlamp fuses. That's if it is wired correctly of course.
www.classicretrofit.com
Old 01-21-2018, 02:17 PM
emac's Avatar
And why is your Positive Cable Black?
Ernie
Old 01-21-2018, 02:41 PM
At least one of those looks like it’s soldered into the lug which can burn the wire insulator.
Old 01-21-2018, 02:47 PM
Jonny H's Avatar
Ernie
Cable to starter is black even thought it's positive.
Old 01-21-2018, 02:51 PM
Platinum Member
dad911's Avatar
Sorry Bob. You're right. A little cryptic......rushed reply.
Any corrosion in an electrical connection causes a voltage drop when current flows through it. More corrosion is more heat/larger voltage drop, until it fails.
New bolt and perhaps some new ring terminals are in order.
3rd_gear_Ted's Avatar
Get yourself an covered auxiliary terminal strip that will accommodate the wire lugs and mount it somewhere nearby.
The unfused leads need to have some inline fuses terminated to the terminal strip also for proper protection.
Get some red tape and wrap that big black cable; WTF
1980 911 - Metzger 3.6L
2016 Cayman S
Old 01-21-2018, 02:59 PM
