Unknown switch
Hi,
While replacing the heater flapper inner and outer cables I decided to remove the brake handle assembly and paint. I ended up with this switch on the side and have no idea where it goes. Thank you for your help. ![]()
1974 911 coupe 4 speed |
IIRC, that's the E-brake warning light switch. It causes the brake light on the dash to blink if the brake handle is up when the ignition is ON.
EDIT: After further investigating, I'm going to retract my guess. That is not the switch for the E-brake warning light. I never had a car with heater blowers, but I suspect that is the switch as others have mentioned. E-brake did not have solid yellow wires and was shaped differently.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 01-29-2018 at 08:21 AM.. |
I believe that your heater fan switch. Controls fan in engine bay when heat leaver is pulled
Now I’m curios as there is another switch for the e brake.
I have two levers for the defrost\heat. How is the fan from the engine bay being activated?
That switch bolts to your e brake and levers. I’m not in shop or I’d send pic. Pull lever, switch makes contact, sends power to fan
Also, when are the heater flapper boxes closed? When the levers are down? And does that mean the spring on the heater flapper box is always stretched until open?
1974 911 coupe 4 speed Last edited by kavadarci; 01-28-2018 at 06:37 PM.. |
Anyone has photo of this switch in the correct location?
Thank you
1974 911 coupe 4 speed Last edited by kavadarci; 01-29-2018 at 02:25 PM.. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Yellow wires.
My factory manual (1986) shows one yellow wire
at the heater lever switch. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Heater boxes are closed when the levers are UP (this means all the heat is flowing through the boxes into the passenger compartment). With the levers all the way down, the ports in the boxes should be open, allowing the heat to escape to the bottom of the engine area.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
That’s he part hat confuses me as down is closed up is open, in my mind at least.
So when my levers ar up I should adjust the cable to have the flaps closed and spring engaged. Again something tells me why would you have the spring engaged all the time? Ah i might be thinking too much. I can’t figure out this switch location but if levers go down to open then the switch should be on for the fan to kick in. I can’t find a spot for it.
83 911 Production Cab #10
When you pull on the lever, the switch turn the blower on and you get heat in the cabin. All the way up for maximum heat.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Wow
I would not have figure that out. I really appreciate your help. I’m saving these photos
Actually I just realized mine is busted, it is missing one tooth and the other is mangled.
Crap. who sells these? thank you
Ok here is what is broken, the one highlighted in yellow.
Is this part available?
Here is the part I need
That piece, 911 424 735 03, the switch, 911 613 525 00, the fiber washers, 911 424 737 00
Paint remover, your choice. Krylon semi-flat black.
No luck finding that piece, the switch is available.
Hmmmm Any suggestions?
Dealer. Or maybe someone here has one.
Nextime you are in Ottawa you can buy me a beer ![]() ![]()
