| Registered User Join Date: Dec 2016
				Lights on = Speedometer off
			'79 SC electrical gremlin. When I pull my lights on, the speedo dies. Any ideas?
|  02-01-2018, 02:41 PM |
| Administrator Join Date: Aug 2016 Location: Los Angeles, CA
			Hello - take a look at the link below to an earlier thread where this is discussed. Hope this helps you a bit.  Speedo dies when headlights switched on? | ||
|  02-01-2018, 03:46 PM |
			Thank you so much. Will take a look!
|  02-01-2018, 06:21 PM |
| Registered Join Date: Nov 2013 Location: Vancouver
			Did this happen recently? If not, it may be because the speedometer lightbulbs were plugged into the wrong holes in the gauge. ... I know cause it happened to me. My parking light indicator was plugged into the speedometer light hole so it turned on when parking lights were on, but off when headlights are on. | ||
|  02-01-2018, 06:35 PM |
