Dashtop replacement / repair options
Good morning - my front window is out for a respray so now would be the time to repair or replace my dashtop.
It looks like replacement dashtops are around $1-1,500? Are there cost effective repair options? I am in SoCal if there are local shops to be aware of. Thanks!
1967 912 (now w/ 50% fewer random holes in it) 911 w/ 3.2 1974 914 (3.2L swap underway) 1984 928s (S4 engine and suspension), 1987 928S4 |
Vulnerari Praesidio
There is only one shop I would send my dash to for repair Porsche Interior Restoration Leather Craftsman Classic 9 Leather
or just buy a new one.
"Wisdom is knowing what to do next; virtue is doing it." - David Starr Jordan |
Thanks Roswell. Have you used them? Ballpark cost?
Is AIR still doing these? Just Dashes still running $1200+ and 6 months?
I can't say for certain if it would be cheaper, but I imagine it would cost a lot less than $1500 including shipping... https://www.awesome.eu.com/ |
Skip... very $ effective option is DIY. Flip side is time one must invest. Forgot exact hours but am guessing 8. That's after having everything needed in hand. Cost for materials is maybe $80 give or take.
Recovering Dashboard Using Epoxy Gel Adhesive
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Thanks folks. Let me check out that link Karl.
George Eshaghian (george@autoinno.com) recovered mine for less than $1000, and it looks great!
Jason - Austin, TX 82 911 SC targa (gone, but not forgotten) 92 968 coupe |
Tom - I've recovered two dashes myself with good results. Remind me when I see you next and I can show you the dash for my '75 that I recovered. It was a throwaway dash top and I'm really happy with the results.
Gabe |
Here's my DIY before vs after. My old dash was so bad and and had been "repaired" once before with sheet metal flashing and drywall screws.
I purchased a dash cap to create a smooth surface to recover. I used contact cement and 4-way stretch vinyl to cover the dash. It took a couple of hours and I'm in it about $150 for the dash cap, vinyl and contact cement. It's a relatively easy DIY job so I recommend doing it. ![]()
Wow, nice work Gabe. Will take you up on that.
Thanks!
86FlatSix
used dashboard
I got a used dashboard in very good condition from a dismantler in Huntington Beach for $420 boxed and shipped to NJ but that was about 3 years ago. It's the larger vents for 86 to 89. Not sure if early ones are far more expensive.
The 2nd photo below shows when the one I ordered arrived (bottom piece) versus the old one which was warped on the AC center vents (top piece). ![]()
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
Thank you for all of the responses and ideas, very much appreciated.
