-   -   Upgrade a 3.2 to a 3.4? (http://forums.pelicanparts.com/porsche-911-technical-forum/986317-upgrade-3-2-3-4-a.html)
Trakrat 02-02-2018 02:51 PM
OK all... I've been researching what's involved with getting a set of 3.4 pistons and cylinders and slapping them on my 3.2.
I came across the following post from Wayne on here:
"...if you upgrade to the 3.4 pistons and cylinders (not necessarily recommended for use with the Motronic system)."
Does anyone know WHY Wayne mentions that this is NOT recommended for the Motronic system?
I plan on keeping my Motronic fuel injection system on my '87.
I believe I would only be increasing my compression from 9.5:1 to 9.8:1... but after more searches on here, I've come across some threads with others saying a twin plug is needed???
TRE Cup 02-02-2018 03:04 PM
We have not had any problems with motronic 3.4 builds. contact Steve Wong at 911chips.com for help in programming a chip that works with this
Bill Verburg 02-02-2018 03:12 PM
There are or at last were 2 versions of the 98mm Mahles available
v1 has a wedge dome for use w/ CIS and Motronic, 9.8cr
v2 has pocketed high dome for use w/ carbs/mfi & other ITB type intakes, 9.8cr, These pocketed domes allow for S and racing type cams to be used
Trakrat 02-06-2018 07:18 AM
Good to know... thanks... I'll verify what kind of piston shapes they are before purchase.
Trakrat 02-06-2018 07:19 AM
Wonderful.. thank you. I bought a custom chip from Steve last year and he had mentioned that once I have all my mods put in place, to let him know and he'll reprogram the chip.
