antenna plug for 1978 targa
My targa has two antennas. The drivers side is an electric and has not been used. It is just a stub. The right side is a normal antenna. I have looked at removing the electric antenna but have not figured out how. I have my door being repaired along with a windows out repaint. What can I use to plug the antenna hole if the shop can get the antenna out?
Old 01-18-2018, 09:34 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
Due to the fuel filler, electric antennas on SCs came in the passenger side fender, and unpowered antennas on the driver's side. Kind of strange that yours is backwards.
The antenna assembly is simply attached to the inside of the fender. There is a company that makes plugs painted to match, but I don't recall their name off the top of my head. Someone will offer it.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 01-18-2018, 10:09 AM
Vintage Owner
Jack Stands's Avatar
Could you have the body shop weld and finish a plug for the hole as long as they’re painting other sections?
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 01-18-2018, 10:14 AM
ROW '78 911 Targa
timmy2's Avatar
Windows out repaint?
Just have them weld the hole closed with a metal patch.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 01-18-2018, 10:51 AM
There are plugs on E-bay. But I dont really like it as a permament solution, especially if you are painting.
1982 911 Targa, 3.0L ROW with Webers
Old 01-18-2018, 01:47 PM
WP0ZZZ's Avatar
I would like to remove the electric antenna on a 911 SC. The only plug I've seen on ebay is a bit to shiny for my taste (see picture). Do you know if anyone is making black rubber plugs to fill the antenna hole?
Old 02-06-2018, 05:49 AM
TRAM 3/4" NMO Rubber Hole Plug - check Amazon
If you give your word: keep it.
Old 02-06-2018, 06:17 AM
jmz jmz is online now
jmz's Avatar
bumper plugs.com ...or go look around at a hardware store for a black plastic one. That is what I did.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 02-06-2018, 07:43 AM
76 911S Targa
tomswa,
Do you know the make of the antenna? I have the same location as you, driver side behind the fuel filler area. The switch was hidden under the dash, below the radio. I had no idea it was electric, at first. I just thought it was a manual that was stuck. My mistake It looks like the only way to service it is to remove the door. Is that correct?
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 02-06-2018, 07:59 AM
I have the ebay one shown above. I installed last fall and will paint in the spring, i think a light sanding and a shot of rustoleum 7777 and it will be looking just fine.
Old 02-06-2018, 08:47 AM
