Help with front strut ID
Good morning Pelicans,
Thank you in advance for any help you provide.
So my car is a 74S. I believe the front struts to be original to the car although I am not 100%. They were rattle canned red before I bought the car some 30 years ago. I am doing a front end refresh. I removed the struts and painted them. I have concluded they are not Bilstein because they do not have the roll pin.
So my questions are;
1. if original they would be Boge?
2. the threaded piece where the insert meets the tube should have a cap?
3. how do I remove the insert to put in a new insert?
I have attached some photos. Feel free to include any helpful info.
Thanks again.
DRC
Old 01-17-2018, 07:14 AM
group911@aol.co's Avatar
Well, I know Koni's are stamped as such in 74 and pretty sure Bilstein also was so that leaves Boge? You're sure there are no stamps?
Thanks,
Bob
group911@aol.com
Old 01-17-2018, 08:04 AM
Thanks for your reply Bob,
There were some stampings numbers and such but nothing stamped Boge.
Old 01-17-2018, 09:00 AM
The 9 Store
Look like Boge with a Billstein insert. Remove the threaded piece with a pipe wrench. I clamp the area that holds the brake caliper in a vise. The new inserts will come with new strut hardware.
The stampings on the tube are very shallow. Paint and primer might have filled them in.
All used parts sold as is.
Old 01-17-2018, 09:19 AM
djpateman's Avatar
With a green body and a shaft like that it should be Bilstein.
Usually the Bilstein have a roll pin near the bottom to secure the insert, they also have 3.5" Caliper mount spacing. I'm not sure about the missing nut on the top holding the insert in place.
Does the shaft move in and out easily, or does it have the gas preload that the Bilstein are known for?
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 01-17-2018, 09:21 AM
Hi mark- Thanks for the help. You have a good 3.0 for me yet?
djpateman, I painted it green. It had traces of black (boge I believe) but had been rattle canned red.
Old 01-17-2018, 09:23 AM
The 9 Store
Might have an engine coming in next week. PM or text me your number again.
I just did the same thing as you are doing with the same strut and insert. There's probably a tool to remove the threaded retainer but since you will get a new retainer with the new insert, a pipe wrench is easy. Billstein no longer recommends oil in the strut tube but I use some heavy grease on the threads so they don't corrode.
Old 01-17-2018, 10:01 AM
gearhead
Boge housing will have both a part number and a date. I have several sets and they all do.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 01-17-2018, 10:03 AM
Thanks Matt,
There are numbers stamped in the housing so that would be consistent.
Old 01-18-2018, 04:53 AM
Under the radar
Trackrash's Avatar
3" caliper spacing? Most likely Boges.
Gordon
'71 911 Coupe 3,0L outlawed
Old 01-18-2018, 04:08 PM
Gordon,
Yes 3" caliper spacing.
In the mean time I have tried everything to remove the threaded nut per Marks recommendation. I can't get it to budge. Are we positive this is supposed to come out now that I have completely buggered the threads
Old 02-08-2018, 08:50 AM
The 9 Store
Did you tighten the area that holds the caliper in a vise? Are you using a decent size pipe wrench? Turning the counter clockwise. You can spray some penetrating oil between the strut and the threads but I just did a set of these that were really corroded and I had no trouble.
Here's a tip that works with any tight fastener, tighten the fastener a tiny bit, just enough to break the bond, then loosen normally.
My pipe wrench is a $15-20 home depot special and it grips fine. If you have it in a vise, you should be able to get some good leverage.
Old 02-08-2018, 03:20 PM
Registered Minimalist
75 911s's Avatar
Hmm... I don't see the nut on your insert...
Stock boge from a 75
Under the dust cover
Original insert is out
Close up of the new bilstein insert.
When the nut is tightened after the new strut is installed, a 4mm gap will remain. Do not try to tighten beyond this.
Edit: Looking again at your insert. Can you take a wide pict of the whole assembly?
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 02-08-2018, 03:44 PM
Mark,
Used a big set of channel locks. I did heat it up tighten and then try and loosen. No go. I'll try my mama jamma pipe wrench.
Hey Duane,
Thanks for the post. I don't have a pic of the assembly in one pic.
Old 02-08-2018, 04:32 PM
Under the radar
Trackrash's Avatar
It looks like the OP's strut has had the aftermarket Bilstein inserts installed. I have no experience with that particular instillation.
What I do know is the Bilstein insert is upside down compared to the original Boge insert. There are bushings in the top of the strut to guide it.
The question is, how were those bushings installed and how do you remove them.
Gordon
Old 02-08-2018, 04:33 PM
75 911s's Avatar
Is it me or is the strut housing bulging where they threaded the bilstein insert in? Maybe the only way out is heat the housing and cool the insert some how.
Old 02-08-2018, 04:51 PM
Gordon-Duane,
Thanks again for chiming in. Duane it's the photo. There isn't a bulge. I did try heating maybe a bit more and the mama jamma pipe wrench. I'll try tomorrow.
Old 02-08-2018, 05:01 PM
WP0ZZZ's Avatar
Is there a guide somewhere on how to identify a strut?
Old 02-08-2018, 06:15 PM
The 9 Store
They look normal for 3” Boge struts.
Old 02-08-2018, 06:23 PM
75 911s's Avatar
Generally just color and as mepstein mentioned they are marked.
Red Koni
Black Boge
Green Bilstein
And Blue for woodhead. Yeah woodhead. :-D
Old 02-08-2018, 06:25 PM
