Another 2.7 vs 3.0 question - 2.7 experts please chime in
I need help from the collective wisdom here. I've read Wayne and Bruce Anderson's books and just about every thread here on the 2.7 vs 3.0 debate. However it's 2018 now and finding a good cheap used 3.0 motor is not as easy as it was back in the day. So I'd like to remove the "just buy a good used 3.0 and forget about rebuilding your motor" argument for now.
Here's the deal. I have two motors - 1. My 2.7 that's original to my '75 911. Appears to be 100% original, never rebuilt. It runs well but it smokes and leaks more than my weird uncle Stu. 2. A '81 3.0 motor that appears to be solid but has 1 broken head stud. This motor was reported to a good runner and appears to have had a top end rebuild at some point, but they didn't change the case studs to steel ones. Here are my assumptions - what would you do? 1. I assuming that both motors will have to be rebuilt with the case split. I might get away with just a top end on the 3.0 but I would want to split the bottom end to check condition since it doesn't appear to have been split. 2. I know the 2.7 will require more expensive machine work than the 3.0. 3. The 2.7 is the original motor to my '75. My '75 is undergoing full bare metal rebuild and steel backdate. It's going to be a really nice car but not stock original. I'm looking to build a fun and solid driver that I'm going to keep forever. 4. I plan on keeping the bottom end stock and going Megasquirt EFI and EDIS with cam change. Not sure if I want to change pistons / CR at this point as I'm trying to keep some money in the bank account. I'm looking for 200-225 hp with excellent drivability and reliability. 5. Seat of the pants fun, great mechanical 911 sounds and throttle response are my primary goals over HP and speed. I know that financially the 2.7 will be more expensive to rebuild. However there's something awesome to me about a hot 2.7 vs a stock 3.0 in my book. Also, the 2.7 is the numbers matching engine to my 911 so from a value perspective, I think the added rebuild cost of the 2.7 may be recouped IF I ever sold the car. I realize that the 2.7 is the "harder way" vs the 3.0 with similar power. However the 2.7s I've driven seem to "rev better" and better throttle response than the 3.0s. I realize this is like the blondes vs brunettes question.. but what you do? |
I scrapped my 2.7 from my '77 and installed a 3.2 built from an '80 3.0 over 20 years ago. It was built by famed local racer/builder Rudi Bartling and was from a car that had been stolen but subsequently recovered. I has lots of torque and is fun to drive. Supposedly it has about 220-230 hp but I've never had it dynoed. It was twin plugged but I've always just used it with a single plug distributor. If I ever want to spend the $3000 or so I could convert to the twin plug distributor which would allow me to use regular gas, but wouldn't change the output. This engine is an old school mod that was done back in the '80s and still uses CIS. Along w/ a Dansk/SSI combination, it sounds great and pulls very strongly even after 100,000 mi.
As I said, it's old school. Today there are other, maybe even better ways to do this, but I still like it! |
gshiwota,
After all the changes you are talking about, you will not have an original car - so don’t try and save something just because it was stock. If you’re backdating the body, you no longer have a stock car, and there is no benefit to keeping the original engine. You can always store the 2.7 as the original engine for resale and build the 3.0 as you want. It also sounds like whichever engine you build will not be stock either. Once the car is not stock…….it’s not stock anymore. |
There is no replacement for displacement. Shelve the 2.7 If you can and you’ll see at sale time if anyone is interested in paying extra for it to get the original case. |
I went thru this myself maybe 6-7 years ago. I replaced the 2.4 with a 2.7 in my 72 and ran it for years. I wanted performance and was looking for 10:1 power/weight. I went thru a weight reduction program ( much cheaper than adding HP). The car now weighs 2200 lbs. I was told that to build a 2.7 to over 220 hp would require some case work as well as the other upgrades $$$$$
My research showed that the only problems with the 3.0 was the case studs. I purchased a 3.0 out of a wreck. I bought Waynes book and decided to do it myself. With the help and advise of Mike Bruns at J&B racing I began my rebuild. You know when you are there you find some little additions that make sense since you have the engine open, so I made some reliablity and performance upgrades. A special cam with lower torque peak but still makes HP (214 ft/lbs @ 4400 and 250 HP @ 6900 rpm tuned on a engine dyno after two days). I only used J&E 9.5 pistons but cut the heads for twin plugs. I still have Webers but had them opened up from 40mm to 42mm. This engine has been bullet proof, which was my objective. It has 20,000 + miles so far and I just run the s**t out of it and adjust the valve and change the oil once a year. What more can you ask. Oh, my car has 241,000 miles on her.http://forums.pelicanparts.com/uploa...1518282901.jpg |
Go 3.0-3.6 if you’re going to slash the value and cut the car up.
Maybe sell the car in original form and buy an already backdated car. Addressing the leaks and new P&Cs might be all it needs. Not all of these have pulled studs/need case halves re-worked though it is a wise thing to do. 2.7 being mag is lighter. |
My background: I've got a '75 Targa that I acquired with a "frankenmotor" - 2.4 bottom end but 2.7 heads & CIS. I rebuilt this into a stock 2.7 CIS motor. The car is not a bare-paint resto by any means - more of a rolling "lightweight" project. Engine runs very well, revs freely (and likes it) and is a hoot to drive.
If I had to do it over (and was counseled by others to do so from the beginning but didn't listen), I would go with a 3.0 (or bigger) and build it the way you're suggesting with more modern engine control. The slight edge on lower-end torque provided by a 3.0 is a valuable asset for daily-driving on the street. I'd also look at taller 5th gear for highway cruising. Porsche did have a few improvements between the 2.7 and the 3.0 and those are worth it. Thermal control isn't as much an issue (but doesn't go away either). EFI and EDIS properly done on a 3.0 will make that bulletproof and fun to drive. Last but not least - if you ever have to sell the car - the "stigma" of an installed 2.7 (no matter how well done) may actually bring lower prices (even if original) than a well-built 3.0. Best of luck. |
Buy new rod bolts for the ones you pull out. |
The 2.7, built right, is an awesome engine and one of my faves to build into a hot rod motor. I'd stick with it.
regards, al |
I know two local guys who are running EFI/ITB on a rebuild 2.7 with CR of 10.1:1 (JE pistons) with DC20 cams, single plug. These engines are very strong and extremely fast revving - perfect for a narrow body hot rod in my opinion.
It's a no brainer to go with the 3,0.
If you are at all worried about resale at some point, put the 2,7 in a crate and save it. |
Agree 100%. Pressure wash/steam clean the 2.7, spray every nut/bolt with Kroil Aero, and crate it, rebuild the 3.0 from the bottom up...
I had a good 3.2 and the stock 2.7 in my car when I was racing it. I went through a similar conundrum. I did a top end build on my 2.7. The formula was 9.5:1 JE pistons shimmed to 9.8:1, DC40 (Mod S) cams, early exhaust, recurved distributor to RS spec (easier and cheaper to do with Edis and I can give you the table from a subsequent build), ported heads to 36mm like a 2.7RS, Weber Carbs with 34mm chokes (I also have 36mm), PMO manifolds. This dynoed at 215 at the wheels and would do better with the 36mm chokes. Also I have the 7300 rpm rev limiter.
I expect you could sell that 3.0 to cover your costs. |
2.7 or go 2.8 even, all day. My shop is about 2 miles from Road Atlanta so we have a wide variety of every manner of modified 911 engine coming through here. The 2.7-2.8 engines rev better, sound better, and just plain drive better imo. I’ve driven umpteen zillion of both. The juice is worth the squeeze. 3.0 is a quick and easy way to go but they don’t check all the right boxes unless you dump a fortune into building one with very light internal components so they feel and sound lighter. Good luck and keep us posted!
Gshiwota, I am right in the middle of this same exercise. I've got this 74 here with an 85 engine in it. However, it's on the original CIS and the seller of the car said it was a 3.0. It's a mystery really, but the red fan might be an indication of it's roots. Project one has been acquiring everything to build a 2.5SS on a 7R case. I'm far enough along that I'm starting to ship off stuff for machine work. I'm hoping to have t assembled and in the car by end of summer. I'm back and forth on Webers versus MFI. I have gotten both and will likely install both at some point. Then I've got a new core to play with. Assuming it's built as a 3.0 I will keep the crank and rebuild it as a 3.2ss and maybe EFI it. My 75 has a 2.2e engine in it, so I need something else for it long term. I'll let you know the results of myjourney in 2-3 years? :D |
Thanks for the feedback so far, this is a really good debate.
I'd love to hear more from those with experience owing a 2.7. I've daily driven several 3.0 and 3.2 cars so I'm pretty sure I know what to expect with the bigger motor. In my brief seat time with my current 2.7, it felt sharper and lighter. Anyone with EFI on their 3.0 want to chime in? I imagine EFI improves the throttle response and wakes up the motor. |
I always preferred the mag 2.7, especially the 7R case with S cams, pistons, and a real exhaust. Webers on that package were a lot of fun, but it sure sucked down the fuel.
My 75 911s all original but heat exchangers deleted have been making 3.0L and 3.2L work very hard in order to see my tailpipe.
I haven't done this but I've driven both enginges and my advice would simply be - don't backdate car if you gonna stick with 2.7 - actually don't back date at all!!
Build that hot rod 2.7 numbers matching in the original body work - maybe do glass bumpers to get weight off but middies have a real specific non-flared impact unique beauty!!!!!! That said, if u neeeeeeed to backdate then go 3.2SS all day long |
I've been running an MFI 2.7 for years, its a great motor, but if I were going to use EFI, I'd go for the 3.0.
I have a friend who built a high compression 3.0 running K-Jetronic and it was fabulous. He is a very experienced engine builder so I'm sure there was some trick stuff. If I had a 75, I would not backdate, make an IROC 3.0. Cheaper and a great driver. |
No quote function today?
From unclebilly "I had a good 3.2 and the stock 2.7 in my car when I was racing it. I went through a similar conundrum. I did a top end build on my 2.7. The formula was 9.5:1 JE pistons shimmed to 9.8:1, DC40 (Mod S) cams, early exhaust, recurved distributor to RS spec (easier and cheaper to do with Edis and I can give you the table from a subsequent build), ported heads to 36mm like a 2.7RS, Weber Carbs with 34mm chokes (I also have 36mm), PMO manifolds. This dynoed at 215 at the wheels and would do better with the 36mm chokes. Also I have the 7300 rpm rev limiter." This has not been my experience. My new 3,0 with JD cams and JE pistons revs just as quick as my old SS2,5 did and it had a T crank. I am no longer considering a lightened flywheel in fact. Plus I did not have to port the heads or do any case work. Easy 250HP with cams, pistons and carbs. In a perfect world a 2,8 or 2,9 with twin plugs and MFI or EFI on a mag case would be my first choice. But I can and did get comparable HP for less $. YMMV. Is it just me when I click on "quote" nothing happens? |
Trackrash, quote isn’t working for me either.
Something is wrong with the site. Look at the column for “Last Post” and noticed that it hasn’t updated in 12 or so hours.
It would depend on your end goals.
If you plan on driving the crap out of the engine, I would pick the stronger 3.0 case. If this is a valuation question, who knows ? The marketplace forum might have better insight into that. |
Thanks everyone for your feedback.
Based on the feedback I'm probably going to start tearing with my 3.0 to replace the headstuds. I'll check the rod bearings as suggested. If I can get away with only headstuds I'll be far ahead in terms of cost compared to the 2.7. I'll post pics once this is all done. Thanks all! |
There is no debate .. never has been , 3.0 is a superior motor in every way .
Just replace the head studs and start driving. |
What do I like about it? Throttle response. If my pinky toe Twitches the tachometer jumps 2,000 rpms. Needless to say I've developed a serious twitch in that pinky toe. |
Another plus for the 3.0 is the heads have larger valves that can support a lot more flow. Might outweigh the lighter 2.7 but only by a whisker....
Like 911s, you want an engine in the best condition possible. |
Also, the rotating mas is a variable. My 3,0 with JE pistons, which are much lighter than the OEs, is as responsive, as I would want in a street driven motor even with a stock flywheel. Repeating what I said, my first choice would be a mag case 2,8 or 2,9 with twin plugs, etc. However after I did the math, the 3,0 just made more sense. |
I believe the OP is on a bit of a budget considering he isn't going to split the cases to address the 100k+ miles (?) of wear on that bottom end of the 3.0L and a correct 2.7L rebuild, even to stock specifications, is not something I would approach with the word "budget" in my head... OTOH if I misinterpreted and $$ isn't an object I would build the 2.7 up from scratch with a linebore, custom crank/rods/pistons, timeserts, etc. etc. etc. and top it with ITBs and Megasquirt controls (or talk to Al Ikosmal for a custom build!) and some Rarly8 headers!
i like the way you think, but i might be slightly biased....... regards, al |
You have to laugh, same as the old 327 vs 350 debate. and then someone else has to throw in the LS(X)
In pcar talk it is 2.7 vs 3.0 and then throw in the 3.6 If it was me, I would build both. |
the 2.7 proponents seem to hang their hats on the throttle response issue, hard to tell which version of 2.7 they like so much but I'd bet that its either an MFI or carb version
Throttle repose is going to be crisper w/ any intake that consists of ITBs, MFI, carb and aftermarket ITBs fit the bill, Any single throttle body system like CIS or Motronic has too much volume to fill between the throttle valve and intake valve to ever repons as crisply. That said you can make a 4.0 w/ as crisp a response, just use the right intake, cams, compression and tune The one thing that you can't take away fro the 2.7 is it's light weight, per Porsche 2.7 400#, 3.0 418# One thing I've noticed is all the PCA 2.7 racers using an al. replacement block due to this sort of thing http://forums.pelicanparts.com/uploa...1518560567.jpg but that can happen to al too http://forums.pelicanparts.com/uploa...1518560747.jpg This 2.7 crank ran for 20min like this, no damage to the block http://forums.pelicanparts.com/uploa...1518560885.jpg http://forums.pelicanparts.com/uploa...1518560885.jpg |
Just to add my useless 2 cents......there are so few '75's that are original their value is going up up up. And if it is a street car, and will be after you are done....why wreck it with a back date? I have a '75 but when I got it someone had already ditched the 2.7, put a steel wide body on it, put an M64 3.6 in the back, let it rust in bad places, and could not get it running. She was gong to be crushed, and I am bringing her back to life, but not back to stock. She is too far gone to ever be worth much in stock trim, vs putting in as much work to build her the way I am.
My story.....I wanted a warmed up Carrera, and already owned a 25th Anniversary 3.2 Carrera (one of 240 built, 107k miles, original, and a little beat on the outside). I was seriously considering doing some reversible but typical mods....up to maybe sourcing a 3.6 and saving the stock motor "if I ever wanted to go back." I wanted it to be quicker, more fun, etc etc, and it was always going to be a street car. My friend however went looking and found my '75 on Craigs List for stupid cheap money. He wanted me to keep my Carrera stock and enjoy it as it would be worth a lot more, etc etc. So I bought the '75 as I could always sell it for p[arts for less than I was into it, if I could not get it running. I could not be happier. My 3.2 is an amazingly fun car, and wonderful stock. My '75 Rat Rod is running and a blast to drive, and VERY different from my Carrera. Both are as enjoyable as the other. The biggest diff, I don't care about my mileage at all on the '75....because it is irrelevant....and its loud and very fast, and not refined, and I can do what ever I want to it. Long story longer.....if you are already doing all that work on your 75 (bare metal) and she is a survivor.....leave her stock, and make her immaculate. She will never be a '74RS 2.7, and as a street car it is not really that much more fun to drive a stock '75 vs what you are building. Sure it would be quicker, and louder....but not the street both are amazingly enjoyable. Different wheels, SSI's etc on a stock '75 would be a blast, and its all bolt on and reversible to stock easily. She would be worth a lot more then too, esp over time. If you REALLY still have the hot rod bug then hunt for a project car like I did if you REALLY want one. With the 3.6 in my '75 it is a BEAST not the street. Today in light rain she spins the rear tires in 1st at half throttle, and in 2nd she can if you really whack her, and thats with 255 rears. Very fun and fast as my 996T seat of the pants (and math). A warmed up 3.0 is going to be FAR LESS fast than that, and devalue the car, maybe more than a 3.6 conversion would since 3.6's cost so much more. Building a warmed up 2.7 might not be as bad as even pistons etc are reversible at rebuild time, and she is not a low milage concourse car. Again just my 2 cents. A friend here is rebuilding a 75 back to original....going to be a blast to drive on the street. |
You should thank your friend for talking you into that. It just goes to show the ideal number of Porsches is (current number)+ 1
Thanks again for all input. Fortunately (unfortunately for some) the all steel backdate and bare metal repaint is already done. I kept it narrow body but it's already a bastard body with a 912 hood, dansk longhood latch panel and turn signal housings, 912 rear bumpers. My metal guy is great, didn't cut corners and it's hard to tell its not factory since we used factory parts.
Yes I have a budget and unless I can sell my kids and my dog, the 3.6 with ITBs will have to wait till the kids are old enough to support me. Sorry to the "restore it to original" crowd, this is my 5th 911 and 8th air cooled Porsche project and I'm tired of going stock. I'm finally building the car the way I want it and not for the next guy. If it makes you feel better, I restored my other 7 cars to stock. :) |
