Kendall oil users. Which GT-1 do you use?
I see they have GT-1 regular, GT-1 synth blend, or GT-1 full synth.
Most everyone refers to them as just "GT-1". Are you using the regular oil or one of the synthetics (blend or full)? |
20/50 regular for me.
Non Compos Mentis
Ditto John. 20w50.
20w50 dino oil for me
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Senior Member
I'm the same as John. Well, I'm easily a hundred pounds and six inches smaller. (total height is what I mean) And I know less than 1% of the stuff he knows about Porsches.
But we have motor oil in common, at least. 20w 50.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
20/50w Kendall GT-1 Racing dino oil for me as well ... in one form or another for about 30 years.
Chuck |
Just switched from Mobil-1 15w50 to Kendall 20w-50 to try to tame some very same seal leaks, I'll keep you posted.
Keith |
Thanks guys.
Can I assume that Chuck's reference to "racing" is more about how good he feels the oil is versus a specific product? Kendall information doesn't support a "racing" oil. Maybe there's one out there but I couldn't find a reference to it. |
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Posted this on the Early 911-S Registry message board on 12/21/00
Chuck oil survey -------------------------------------------------------------------------------- For what's it's worth, I've been around racing since the late 60's and I've been running KENDALL GT-1 Racing Oil in all my cars since the early 70's ... used straight 40W until the 80's then switched to 20-50W. I live in Southern Cal. where the temp. is mostly warm to hot. I presently run this oil in a 98' S-10 pick up, a 67'Mallabu, and of course the 73' 911-S.... In the past I've ran this oil in an Alfa GTA C-Sedan, Formula Ford, Formula Atlantic, 55'Chevy drag car .... and the list (between me and my racing friends) goes on and on. Check it out yourself at the track ..... It always makes me smile when I walk the road racing, drag, and circle track pits and see the 'black cases of green-death' over in the corner even when there might be the name of another oil on the side of the car.......... Again, for what it's worth ------------------------------------------------------------------------------------ This was posted before they changed the color of GT-1 from green to gold. Sorry, the ID reads 'High Performance' not 'Racing' |
