Center Vent Help
I have a 1977 Porsche 911. I seem to be having an issue with the center vent. It doesn't fit flush. It has open spaces on all sides. Do I have the right vent? If not can anyone help me please? Thank you.
Old 02-16-2018, 09:38 PM
Hellraiser's Avatar
Send a message via MSN to Hellraiser
You have the dash of a 3.2 in your car
Old 02-16-2018, 11:29 PM
proporsche's Avatar
hi actually your dash is from 1986-89 911 Carrera..
Ivan
it takes this kind of grille
1985 911 with original 502 191 miles...808 198 km
Old 02-17-2018, 12:22 AM
4flyboy's Avatar
You need a next generation air vent
You can pick up a used vent here on the boards and it'll snap right in.....you're gonna like it. Bigger is better, particularly in So. Cal
Sell the smaller one to a guy with an SC or Carrera through 1985
Scott
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 02-17-2018, 03:44 AM
4flyboy's Avatar
Ashtray
BTW: you can also pop the ashtray out, sand, tape and paint the metal lip.....it'll look great.
Just sayin
Scott
Old 02-17-2018, 03:45 AM
MBAtarga's Avatar
Scott
I'm not that familiar with the dimension/geometry of the larger vent insert. Does it require the metal opening behind the actual dash cover to be large enough for the plastic housing to be inserted? If so, the '77 dash opening will be too small.
Mark
'83 SC Targa - since 5/5/2001
Old 02-17-2018, 05:57 AM
If the dash is a later Carrera then you will also need the later hose adapter piece and seal as well as the vent.
Old 02-17-2018, 06:56 AM
proporsche's Avatar
the original OP should take the vent out and see.
Most of the time if someone updates their dash they already cut the metal to fit the newer vents.
Ivan
Old 02-17-2018, 07:09 AM
Thank you all for your help.
Old 02-17-2018, 08:11 AM
4flyboy's Avatar
Hey Coleman,
Let us know how it plays out?
Scott
Old 02-17-2018, 06:36 PM
Okay so i have the center vent but it doesn’t seem to fit. It looks like i have tontrim the metal. Correct?
Old 03-02-2018, 12:56 PM
proporsche's Avatar
hi.yes that is correct
Ivan
Old 03-02-2018, 01:08 PM
Thanks for everyone’s help!
Old 03-06-2018, 04:04 PM
Where is the hose that connects to that vent though? I have a 75 that I am about to put a Carrera vent in, like you now have. I am interested in finding/seeing the piece that hook the round hose from the blower onto the back of this vent?
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 03-06-2018, 07:16 PM
