Should parking brake handle be curved?
1978 911SC
I'm pulling out the parking brake handle assy to re-paint and noticed the handle bends towards the driver. Is this intentional to clear the heat controls or damaged? I don't want to straighten it if it's supposed to be bent...
Administrator
Just asked a colleague and the handle is supposed to be completely straight.
Those two red plastic finger grabbers on the heater controls are available fairly inexpensively. They pull off/push on as I recall. Old ones may break coming off.
It's a while you're there kind of thing. |
More Likeable IRL
maybe an rallye car in another life? you know how rallye drivers love some rear hand braking to help get the arse around in tight corners.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Thank you all. I'll gently try to straighten it. New heat control knobs added to my "project list"
More Likeable IRL
if you are not already aware do not introduce any heat to straighten it while in the car as the fuel lines are just a few inches away from the lever in the tunnel. if you were aware im sorry to insult your intelligence,,, but I had to learn the hard way 15 or so years or so ago applying heat to the tunnel... thankfully my hair grows quickly and my beard was much more managed at the time
'73 911 T Targa
Sure looks like if you straighten it up, it’s going to bang against the inner heat control lever.
Mine curves a little to the right, most do one way or another so I hear. But my parking brake is straight.
More Likeable IRL
there's a bill Clinton joke in here somewhere.....
shh-the robot is sleeping
My guess is that there was a little lovin going on in the passenger seat... one foot on the brake handle. Bent the whole unit including the base.
'88 911 Coupe, 69k miles |
Juanbenae, when it comes to fire I'll gladly take advice!
I pulled the entire assembly apart, chucked it in a vise by the pivot pin and gave it a gentle nudge. Straightened right out. (You guys are funny...) |
