3.0 litre on 69 , do I need brake booster?
My 69 restoration almost being finished ! All the drive train, suspension and brake system came from a 79 donor ! No brake booster installed ! Is it going to be an issue ?
Thanks in advance for recommendations !
Kevin
Old 02-16-2018, 08:20 PM
Old 02-16-2018, 08:22 PM
My '72 with a hot rod 3.2 had carrera non power brakes and stopped fine. Just a tad more pedal pressure.
206 637 4071
Old 02-16-2018, 08:29 PM
Under the radar
Trackrash's Avatar
You are saying you are using the '69 master cylinder? That should be no problem.
Gordon
'71 911 Coupe 3,0L outlawed
Old 02-17-2018, 11:43 AM
yes its just 69 master cylinder ! thanks for the advice
Old 02-17-2018, 04:07 PM
Also, I just retrofitted power brakes to my 75 because I've got a big honking motor in there and I wanted the extra stopping power.
It's a pretty involved job retrofitting the boosted MC that involves welding in the frunk among other things.
Old 02-17-2018, 05:26 PM
Bill Verburg's Avatar
Kevin
As the others have said, no, stock is fine
But you may have the holy grail of non boosted m/c for A/S & M brakes.
Early '69 used a 20.5mm non boosted m/c that is pure gold.
Porsche # 901.355.012.04
ATE # 3.2120 - 3901.3
I haven't seen one in over 40yrs because the only replacements available are the more usual 19.05mm used from ~'69 1/2 through '76
Porsche # 901.355.012.02
Bill Verburg
Old 02-18-2018, 08:15 AM
Yes the master is from 69 as far as I remember ! Thanks
Old 02-18-2018, 06:14 PM
