Help setting up mega squirt with AEM EPM
Hey there, I’m just about done with a major overhaul on my targa (turbo, mega squirt, and some other bits). I have to set up the major trigger settings to work with the aem epm that I’m utilizing for engine position. I’m wondering if anyone has any tips for measuring the tooth offset properly so I can set tooth one and the angle offset. I figured it was worth asking befor I go out and break something on accident.
Megasquirt Support Forum (MSEXTRA) • Search
... maybe you can pick up some info via Megasquirt? good luck, |
Depending on what toothed wheel you used, I’m assuming 60-1 and if you used the stock location for the distributor then you should be 48-50*
Siri got that messed up. Supposed to say if you used the location for the distributor hold down clamp for your fr sensor
| All times are GMT -8. The time now is 05:05 AM. |
