1986 915 Clutch adjustment question
Hey,
I just wanted to confirm that I can make the clutch adjustments at the transmission with the cable attached up front at the clevis.
I recently did a new clutch cable and from what I understand I need to do the adjustment a second time after driving the car. So I’m basically just trying to confirm that I can loosen the 15 mm nuts and then set the 1.2/1.0mm gap while everything stays hooked up at the pedal.
Thanks!
1986 911 Grand Prix White
Old 02-25-2018, 05:56 PM
Yes, leave the cable attached.
- loosen the 15mm nuts
- set the gap to 1.2 mm at the adjusting screw
- then tighten the nuts until the gap is 1.0 mm.
Old 02-25-2018, 07:42 PM
Thanks!
Old 02-26-2018, 04:22 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Don't forget to check your travel (set by the pedal stop in the floorboard) after you've got it hooked up and adjusted as mentioned above
Kevin L
'86 Carrera "Larry"
Old 02-26-2018, 10:27 AM
