Wheel size ??
I am trying to figure out the widest rear tires I can fit on my 91 c2turbo ? what offset do I need I currently have 10'' in the rear with 18/265/35 .I would like to try to fit 315's if I can any Ideas
Thanks C2turbo
We have ton's of new Porsche Dyno's and a new fast link
www.c2turbo.com
I have attached a Pic of 3.8l tt motor that I will be installing next week wish me luck!!
Old 02-22-2003, 05:51 PM
Eric Mckenna's Avatar
3.8ltr twin!!!!!!!!!!!!!!!
Holy CRAP!!!!!!!!!!!!!!!!!!!!!!!!!!!
thats bad a$$!!!!
Eric
Famous last words..
"Hold my beer and watch this...'
" The reason the Irish are always fightin one another is that there are no other worthy opponents ".
Old 02-22-2003, 06:53 PM
I have been working on the project for about 8 months it should put down about 550-575 rwhp at 1 BAR we will have to see ??
Old 02-22-2003, 06:57 PM
Man I wish I had the funds to create somthing like that .. Damn!
you are a lucky man!
enjoy her!!!!!!!!!!!!
Eric
Famous last words..
Old 02-22-2003, 07:24 PM
Mikkel
Guest
Posts: n/a
I have an article somewhere on a turbo with 10x18 rearwheels with 285/30x18 tires. Have tried looking for it, but I have quite a collection of car magazines so it's not exactly easy to find Anyway check JackOlsen's posts. He has really big wheels.
Old 02-23-2003, 09:00 AM
Administrator
Jack Olsen's Avatar
I'm going to be running 11's with 315's, adding a one inch spacer to clear the headers and oil lines.
But my car doesn't have Turbo hubs, so it's hard to say what will work on yours.
Old 02-23-2003, 11:43 AM
aseem's Avatar
Jack, when you add a 1 inch spacer, could you instead "add" 25mm more negative offset? ( if you could specify this when ordering)
Arnljot
1980 930 GT35R, TurboKraft IC, 965 P&C, 964 Cams, Tial WG, ported heads, BLWUR, RarlyL8 hdrs&mfflr, Zeitronix logger & wideband
1989 928GT
1972 BMW 3.0S
Old 02-23-2003, 12:10 PM
Administrator
Jack Olsen's Avatar
Well, we had to build the wheels before we put on the flares, so the one inch of spacing was to give us some play in fitting the new wheels. The new wheels have 6 inches of backspacing. If I did 7 inches of backspacing, I would definitely have some contact issues with the exhaust and oil lines.
But my car has RSR flares, which aren't exactly the same as a Turbo's, and I have the 72 oil tank, which puts things in different positions. When you're getting this big, you've got to make specific measurements for your own particular car.
Old 02-23-2003, 02:10 PM
