Bill Verburg's Avatar
glue on flares
I thought some of you might be interested in a PCA E class 911RS lite weight project, particularly the glue on flares.
The glue on flares go on very nicely and look to be easy to finish. ~1" of overlap.
Bill Verburg
Old 02-19-2003, 08:07 AM
Limbo
Slider79SC's Avatar
So is gluing on the flares the prefered method? I am about to install the flares on my RSR project and we were going to use the screw and welding method.
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 02-19-2003, 08:13 AM
IROC's Avatar
My SC flares were glued on about 6 years ago and I haven't had any problems with them since. I'd recommend it over welding. The joint is probably just as strong and you don't have the issue of welder competence and the resulting potential for corrosion from the heat-affected zone.
My 2 pfennig,
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 02-19-2003, 10:25 AM
Seems to be preferred to me to me, It's neat, quick, no warping, no corrosion issues, seems plenty strong, finish work will be easy as far as I can tell.
Bill Verburg
Old 02-19-2003, 01:49 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
My last two widebody jobs were glued on. This one over 6 years ago and no problems whatsoever. When they were first put on, after drying for two days over the weekend, (before paint or filling bodywork) we put a jack and a block of wood under the rear flare and lifted that corner of the car off the ground. Id say its sturdy!
Old 02-19-2003, 02:17 PM
rattlsnak, was that a stripped chassis? The one in my picture is ~600# I can easily lift either end by myself. 4 people are all that is needed to move it around.
I do agree w/ you, the flares are solidly attached.
Bill Verburg
Old 02-19-2003, 02:21 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
What type of glue?
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 02-19-2003, 03:16 PM
drag racing the short bus
dd74's Avatar
rattlsnak:
You're car's really nice! What year is it? What modifications have you done to it?
The Terror of Tiny Town
Old 02-19-2003, 04:25 PM
rattlsnak's Avatar
Bill,, it was not a stripped chassis,. It had engine, wheels, etc. and all!
dhoward, I couldnt tell you part number of the glue, all I remember is it was a 3M product.
dd74, you'll have to do a search on me for more details, but basically it was a 78 SC that became a C2Turbo, complete with drivetrain, big reds brakes, wheels, etc. all from a 92 C2Turbo... To many things to list.. I have sold the car to a member here on the board, and now I have a 993 that is getting a huge list added to it as we speak.
Marc
Marc
Old 02-19-2003, 05:54 PM
Navin Johnson
TimT's Avatar
If your are going to weld on flares you shouldnt need to use screws
duct tape can be used to locate the flare until you tack it.....
I suppose if you have to humour the flare to its position a screw would work, if you dont have some clecos
Bill, it appears that is steel/steel bonding?
If it is an E class car why not use glass flares and distribute your weight bonus to where you can use it better?
'69 911 GT-5
'75 914 GT-3
and others
Old 02-19-2003, 06:01 PM
TimT,
Not my car, the owner is transfering usable pieces from his old car which was wrecked beyond salvation. He does have some interesting pieces like oem steel '73 RS rear bumper ends that will be replaced w/ f/g. The whole front end will also be f/g We were going through the rear bmper pieces yesterday. It is amazing how heavy the stock 73 bumper is w/ all of the trim. I swear that my 76 Carrera oem wasn't much heavier.
The target weight is ~2060 The feeling is that the car will come in well under anyway.
Yes, steel/steel bond, I have no idea what the cement was. The body shop did that along w/ the bead blasting and self etching epoxy pimer
Bill Verburg
Old 02-20-2003, 04:44 AM
The glue is availible at autobody paint stores. It has been around for a while and works well.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 02-20-2003, 05:14 AM
Here's an interesting article on replacing body panels...including the use of adhesives (long but informative). Compares the "emerging" technologies of panel adhesives and resistance spot welding.
http://www.autobodypro.com/tektips/articles/panel.htm
The adhesive mentioned earlier is 3M Automix.
http://products3.3m.com/catalog/us/en001/auto_marine_aero/automotive_aftermarket/node_GSNCT3JT87gs/root_GST1T4S9TCgv/vroot_GSLPLPKL4Xge/bgel_M1MQQDCT0Hbl/gvel_P14FZGJL4Zgl/theme_us_aad_3_0/command_AbcPageHandler/output_html
Old 02-20-2003, 06:33 AM
I have just started striping my 1975 911s for restoration. I want to go back with a widebody carrera look with steel flares. Thanks to Bill Verburg's reply to my thread on Rennlist I found this thread at Pelican. I intend to have the car acid dipped and use the epoxy method for attaching the new flares.
My question is this; Are there any step by step Tech articles or publications that detail a widebody conversion? I bought the Haynes 911 restoration manual (quickly devoured by my "wifes" Doberman puppy) and the Haynes repair manual. I am more concerned with steps for cutting the OEM fenders and fitting the new.
I want to do as much of this project as I can without professional assistance. I have wanted an old Porsche to tinker with since college and it seems obsurd to send it out to a body shop every few months when the object was a to have a hobby to begin with.
Any assistance is very apreciated ---and thanks again Bill
1998 BMW 323 is coupe
2000 BMW 323 i sportswagon
Old 05-01-2003, 12:28 PM
Bonding Flares
Anyone got some step-by-steps they want to share? I'd prefer bonding vs weld if I can help it. Appreciate the info.
Old 03-02-2004, 09:09 PM
Series900's Avatar
glue is fast, but if damaged later there are some consequences, read thread for explanation
Glue on flares: Who has done this and what have been your results??
Damon @ SERIES 900.com
Sunapee NH
several 911 variants
Old 03-03-2004, 06:24 AM
Glue on Flares
What is the proper method of bonding the flare? Does a step have to be created in the body to match the thickness of the flare? Or is there another method where not much filler is used? Please advise.
Old 03-04-2004, 09:45 PM
cnielsen's Avatar
Does this body glue work the same for fiberglass flares or just for metal to metal?
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 03-05-2004, 03:22 AM
911mike, you can do it either with a bead (step) or without. I think the preferred way is with a bead of up to 1 1/2 inch width. Several different tools can be used to make the bead on the panel edge.
Cnielsen, they absolutely make a bonding adhesive for FG to Steel. Works pretty much the same way.
Warren & Ron, may you rest in Peace.
Old 03-05-2004, 06:17 AM
RETIRED
Joe Bob's Avatar
Just picked up some stuff for the 356 Outlaw. It's called Duramax 4125, got it at the body supply shop.
2012 ML350 3.0 Turbo Diesel
Old 03-05-2004, 09:52 AM
