-   -   What size short block do I have (http://forums.pelicanparts.com/porsche-911-technical-forum/9887-what-size-short-block-do-i-have.html)
bfrenz 11-02-2001 11:01 AM
Ok I don't have a parts number manual so I need your help. I have a short block that has the numbers 901.101.101 OR on one side and 901.101.102 OR on the other side. I would imagine the 102 is for the side designation but what size block is this. Is there another number I should be looking for also.
Thanks to all who answer
rvanderpyl 11-02-2001 12:42 PM
Most likely a 2.0 but post the number on the that is by the fan shroud, ie 901/##
Robert
bfrenz 11-02-2001 12:52 PM
The number by the fan shroud is 3280442.
kstar 11-02-2001 02:11 PM
<font face="Verdana, Arial" size="2">Originally posted by bfrenz:
The number by the fan shroud is 3280442.</font>
3280001-3281606 is the engine for a '67 U.S. Coupe. That's the 901/14 motor at 1991cc making 130hp (DIN) at 6100 rpm.
Should match a 902/0 tranny.
Chassis numbers matching this motor should be 11830001 thru 11830473.
473 of these Porsches in this configuration were produced, each weighing 1080kg.
Hope this helps!
Regards,
Kurt
