bfrenz's Avatar
Post What size short block do I have
Ok I don't have a parts number manual so I need your help. I have a short block that has the numbers 901.101.101 OR on one side and 901.101.102 OR on the other side. I would imagine the 102 is for the side designation but what size block is this. Is there another number I should be looking for also.
Thanks to all who answer
Old 11-02-2001, 11:01 AM
Post
Most likely a 2.0 but post the number on the that is by the fan shroud, ie 901/##
Robert
Old 11-02-2001, 12:42 PM
bfrenz's Avatar
Post
The number by the fan shroud is 3280442.
Old 11-02-2001, 12:52 PM
Monkey with a mouse
kstar's Avatar
Post
3280001-3281606 is the engine for a '67 U.S. Coupe. That's the 901/14 motor at 1991cc making 130hp (DIN) at 6100 rpm.
Should match a 902/0 tranny.
Chassis numbers matching this motor should be 11830001 thru 11830473.
473 of these Porsches in this configuration were produced, each weighing 1080kg.
Hope this helps!
Regards,
Kurt
Old 11-02-2001, 02:11 PM
