3.2 Cold Start Rough Running
I have a 3.2 that has had cap, rotor, wires and plugs replaced within the last 200 miles. but upon cold start it runs pretty rough. once it warms up it runs fine.
before i go tearing in, what do you guys think i should look at first? maybe there is something common on the motors that would cause that. i was thinking o2 sensor, cht sensor, sweep arms inside afm, idk. just ideas thanks
IG @Drola964 1973 BMW 2002 1990 964 C2 2007 GT3 2014 Ram 2500 Cummins |
First thing, re torque your intake runner bolts. They get loose over the years. Allows air to get into the cylinders causing tough starting.. you will need a foot pound torque wrench from harbor freight. And the correct size allen to go on the wrench. Cheap! I think the torque is about 18 foot pounds but double check.
Then check for vacuum leaks.
thanks. yes i thought about vacuum leaks also
Easy vacuum leak check with carb cleaner sprayed at base of manifolds while at rough idle.
