evan9eleven's Avatar
How to remove this AC bracket?
Maybe a dumb question, but it seems this AC bracket has its nut welded to it. So how does one remove it without a mega dissassembly? TIA.
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 04-09-2018, 10:58 AM
proporsche's Avatar
hi..very easy..use 17mm socket with a flex extension and remove...it will come off right away..
maybe just spray over it wd40..replace it with a nut and washer
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 04-09-2018, 11:11 AM
Ivan
Thanks Ivan, I'll give it a go. It seems like the nut and bracket are one, but I'll see if some extra convincing gets that sucker loose. Cheers!
2004 Boxster S
Old 04-09-2018, 12:32 PM
It’s just an 8 thread...
Bruce
Old 04-09-2018, 03:33 PM
Tricky to get on it, but just 17mm if I recall.
Old 04-09-2018, 04:06 PM
Thanks for the replies everyone-- I got it removed with a wobbly extension. It is an unusual nut that has a "bushing" of sorts that fits inside the bracket. Hard to explain but it isn't like a regular nut. With the corrosion on it, it was on pretty tight and looked like it was part of the bracket. Not the case, just a good dose of torque and off it came.
2004 Boxster S
Old 04-16-2018, 12:10 AM
