irl irl is online now
irl's Avatar
Send a message via AIM to irl
Latest low pressure fuel pump??
What are people using for low pressure fuel pumps with carbs these days???
Old 07-27-2018, 03:47 PM
Im using a malory 110, its 7psi so you still need to use a regulator. Nice thing is that its rebuildable.
1982 911 Targa, 3.0L ROW with Webers
Old 07-27-2018, 05:47 PM
irl's Avatar
Pelican sells a Pierburg and a bosche but can’t tell if one is low pressure
Old 07-27-2018, 09:50 PM
Pierburg 912fpmp 3.5#, no reg needed.
206 637 4071
Old 07-28-2018, 04:23 AM
irl's Avatar
The Mallory has a lot of good feedback but it’s sopposed to be mounted vertically and don’t see how to fit that in the original location up front. I’ve also seen And used the pierburg but my setup uses AN fittings on the pressure side and the low pressure pierburgs i see now are just clamped both sides.
Old 07-28-2018, 06:39 AM
irl's Avatar
I can call but crazy Pelican doesn’t have explanation on low pressure vs high pressure or what Pumps are for carbs like competitors. Guessing the lower cost ones are low pressure
Old 07-28-2018, 03:18 PM
Bought one of these, but have not installed it yet. 4psi.
Electric Fuel Pump CARTER P60504
Old 07-28-2018, 06:12 PM
Gordo2's Avatar
Pierburg Universal Fuel Pump
I installed Pelican's universal Pierburg fuel pump. The fuel line sizes were a bit of a challenge, but it works well.
Fuel Pump Switch - CIS to Pierburg Universal
I have a PMO fuel reg with recirculation - the Pierburg remains at a steady 3.5 psi.
Good luck, Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 07-29-2018, 07:50 PM
Senior Advisor
James Brown's Avatar
i like these if there made in USA, period correct for an old 911
08 Cayenne Turbo
Old 07-29-2018, 08:45 PM
