Is there some trick to getting the defroster light screwed back into the floor?
I replaced my shifter bushing a year or so ago and to access it, the center console and defroster light had to get unscrewed.
Is there a trick to getting this damn thing screwed back in? I give it a few tries every couple of months and get frustrated because I can't find the damn hole through the carpet that it came out of. Yes, I feel like an idiot asking this question but it's driving me nuts. |
Use a pick tool, like an ice pick or very pointy tool to first locate the hole through the plastic box.
My test light is a very pointy tool. Works great for this.
I decided to use the blind man losing his virginity method and just kept poking until I found the hole. It was a miserable, unsatisfying process but I finally got the damn thing screwed back in.
Use the same method for floor side panels and door panel storage compartments :-)
Congrats. |
LOL, wait till you drop the engine.
I find the hole in the carpet, poke a wire/paper clip through it, slide the switch base over the wire, then use the 'blind poke' method to locate the other screw.
BTW - what's the correct orientation of the switch - writing facing the front firewall or towards the seats? Both ways seem equally logical. Bill K |
You should be able to read it sitting down, left to right.
| All times are GMT -8. The time now is 01:39 PM. |
