Carmagic.us
Testing Some LED Headlights
A few years back I build a set of HID headlight for my 71 911. That was a lot of work and even to used HID parts were quite expensive.
On the 944 which had 7" sealed beams, I got some Hella H4 with 55/60 watt halogen bulbs, which was quite an improvement over the sealed beams. However, going back to drive the 944 compared to the HID in the Boxster, wasn't that good. So I tried some LED's. Here is what I used: First the H4 Halogen 55/60 Watt, # 1 below. ![]() Next I had the LED's in the Hello H4 lights, # 2 below ![]() Now I got some 7" sealed LED 30Watt, # 3 below and a different one 48Watt, # 4 below. ![]() Here are some pictures of the output. H4 Halogen 55/60 Watt, # 1, typical H4 with the right side going up. ![]() LED's in the Hello H4 lights, # 2, they are bright, but really had a small width and don't give you a lot of light left and right, especially when turning. ![]() 7" sealed LED 30Watt, # 3, not too bad, but they produce 3 dots per lamp, it is not so visible in the picture, but it's there. They don't have a good cutoff and the light makes a bow. ![]() 7" sealed LED 48Watt, # 4, these are the winner, they perform like the HID with a nice cutoff and give a nice light also left and right. ![]() All I can say: Seeing is believing. Now these would fit direct in the cars with the sugar scoop headlights and the 914, 924, 944. Next will be to see how hard it will be to mount them in the Euro H4 headlights. Cheers Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems |
Nice post; thanks for the pictures.
'90C4 |
Brew Master
If you look on the hood of the car in your pic with 3 dots per light, you can see the dots very clearly. I could see them on the garage door.
Nice job! |
#4 is not US...
What's the brand name and model number for units 3 & 4?
I would rather be driving
The only way the 7" sealed versions will work in Euro housings is with a non-fluted lens. The focal points of the projectors will be seriously messed up with an additional focal points of the fluted lens.
#2 and #3 clearly show why you don't want to just install any bulb system in your headlights. The diffuse light pattern and lack of cut-off would blind oncoming drivers with that much intensity. Thank you for testing these and showing the difference between them.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Carmagic.us
Thanks Engelbert
No, it really isn't worth a try, but go for it if you have to see for yourself. You are overlaying two inherently incompatible technologies over one another. The older reflector (which is predicated upon a precise parabolic shape with a specific focal point where a very precisely placed light i.e. the filament, needs to be) with a fluted Fresnel lens to refract (i.e. shape) the beam pattern. Old technology, but also, when done well, provides for precise and accurate beam patterning. See every quality H4 headlight out there. The newer ("less old") projector beam technology with a separate, optically clear, non-fluted, cover (note this is a cover and not a lens), wherein all the beam patterning is done inside the projector unit. Placing a Fresnel lens in front of a projector housing will only serve to compromise the beam pattern and diffuse the light output. I wish I was wrong here, but I'm not. Try the projector + Fresnel experiment on the passenger side of the car Send pics of the resulting beam pattern both against the garage door as well as a frontal shot at about the height of an oncoming driver's head and we'll see. Well, technically, you'll see as I already know what the result will be. Again, I sincerely wish we could have it both ways (Fresnel look with modern projector technology / performance), but this is yet another instance where one cannot have their Kate and Edith too. Thanks for sharing your experiments with us! |
Carmagic.us
Thank you for the clear explanation, and I agree 100%. My point was basically to show what it looks like with the H4 Lenses.
Thanks Engelbert
Eng-o-neer
Are those the JW Speaker 8700 Evolution 2s? I have a pair of 8800 Evolution 4x6s in my Volvo 740 and they are excellent.
None, not one of these would pass inspection where I live.
H4 with clean reflectors, non scratched lenses, and relays remain the best solution today anywhere lights are checked for pattern. Talking about pre-993 911s. |
Eng-o-neer
Are there H4s that are US-legal? I thought only sealed beams and H5s were DOT.
Another great experiment/project! I can see how the 3 spots were created, as there are three "sources" in place of one 360 degree filament.
The projector lens-ed LEDs are interesting. But yes, getting the non "bug eyed look" that owners of non current model 911s etc want is the trick. When I did my HID in an H1 type clear lens-ed housing project for my 911, the functional results were great, but the appearance wasn't. The actual light didn't use the entire clear cover/lens, so I experimented with obscuring the unused areas of the glass with "fluting". But, then I get pulled off the "fun" projects and have had to do things like painting the house, etc, and I never found an appropriate "Fluting" material that could be applied inside the clear lens. I used stick on clear plastic that had patterns, such as you'd get in a local hardware store for putting on bathroom windows for privacy. It worked and really wasn't awful if the car was going 30 and you were 30 feet away, (LOL) and helped prove the concept was sound. Perhaps that could be a option? Need to find "fluting" that can be applied in the lens. (Because getting HIDs or LEDs to act like filaments ...(which fluted lens require) is next to impossible)
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
I realise that this is a dodgy subject but I'll bring up anyway
![]() These look like they might look kind of interesting depending on what they look like on the car: Amazon.com: Lantsun® 7 Inch Round LED Headlight with Amber Signal Halo Angle Eyes with DRL Halo for 97-15 Jeep Wrangler(1 Pair) 022022: Automotive would love to know if they fit, and what sort of beam pattern they make.
1971 911T British Racing Green 3.2L 2013 981 Boxster S Aqua Blue/Grey 2014 981 Cayman S Agate Grey/Black enjoyed and passed along: 1990 964 C2, 2007 C4S Cabriolet, 1997 986, 1958 356 A |
nice write up. But from an aesthetic standpoint systems 3 and 4 to me are pretty ugly.
Carmagic.us
Here is a picture of the #4 installed in my 944 where I tested them.
![]() I got a few more set's now, and will install one in the 911 with sugar scope setup. That is a plug and play install. Next in a 911 H4 setup with a clear lens. Stay tuned. Cheers Engelbert
Carmagic.us
Here are some pictures of the LED's installed in the SC with sugar scoop setup.
![]() Here mounted without the ring ![]() LED mounted in the support ring. ![]() I did also some testing with the H4. Just to see what the pattern looks like, I installed one in the H4 with normal lens. I was actually surprised about the cut-off. Here on low-beam. The cut-off make a slight bow, but it is much better than I expected. ![]() Here the high-beam. ![]() Cheers Engelbert
El Duderino
Engelbert,
I'll be really interested to see your results in an H4 setup. Good work!
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
FWIW, the JW Speaker is available with both DOT flat and ECE up & to the right ("Right Hand Traffic") beam patterns... 0549711 DOT LED 0550231 ECE LED for Right Hand Traffic You will note, they are also available in ECE pattern for Left Hand Traffic 0550211 Last edited by famoroso; 11-28-2015 at 04:49 PM.. |
Cars and Cappuccino
This thread got me hunting. I am thinking these are the #4 lights here on eBay
Ad says DOT approved, but not sure I would trust a random eBay seller. Thanks to the OP for doing this research.
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
