Nux Nux is offline
Nux's Avatar
The Sound of a bad alternator
Numerous threads on this topic. Few sound clips or videos. So thought I would post mine. Engine is 1989 3.2 . The sound is quite horrible but does disappear with higher revs. Thought is was chain noise on the left side, so checked that and even replaced the tensioner (had an extra). No change. Then pulled the fan belt : Voila.
https://youtu.be/kboKTcM3KH4
Old 03-06-2018, 05:57 AM
Kind of Blue
MrBonus's Avatar
Mine was dead silent. The battery light would occasionally show a faint flicker at idle. When I smelled sulfur from overcharging was when I knew it was time to replace it.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 03-06-2018, 06:41 AM
76 911S Targa
Sounds like the bearings are worn and the fan is occasionally dragging on the housing. The bearings are cheap and replaceable. Or you can wait like I did and replace the whole alternator in the parking lot of a motel.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 03-06-2018, 09:57 AM
Nux Nux is offline
Nux's Avatar
Yes. However, I didn't find any play at all in the bearings. Everything looks fine. I suspect it's the alternator it self unfortunately.
Old 03-07-2018, 04:37 AM
Chain fence eating turbo
That's the voltage regulator going kaput
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 03-07-2018, 06:09 AM
