Where can I get a grooved main bearing for a 3.6 964 case?
My supplier is having issues and this is holding up my build so I'm looking for alternative sources for a grooved main bearing to accommodate the add'l oil flow from the cross-drilled crank work. Thanks
1980 911SC Targa 3.6L |
grooved brg.
I have some if you want to exchange a stock one for a grooved one.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Thanks Mike sending you a PM
